felixx wrote:I just discovered this thread and wow oh wow
dirtsailor2003 wrote:My two cents, on insulation, boat building and weird shapes, and things. I'd skin this frame on the outside. Run all my wiring , pipes, etc, needed in conduit. Then have the insulation shot on from the interior.. Closed cell, which doesn't transfer condensation. Then skin the interior. Expensive, yes. But when you're already doing the job you're doing on this build its well worth it.
Caveman1970 wrote:...I wish you were my neighbor!
dave campbell wrote:.... i will do my best to eliminate galvinic corrosion and ghosting of the cage through to the surface by using foam shims, then insulate from the inside....
