Alaskan Benroy
Re: Alaskan Benroy
Postby ratrod71 » Wed Sep 09, 2015 7:19 pm
dales133 wrote:Looking good!
Looks like you have the same gaurds as me,mine were imported to aussie from so cal
I got mine from a local utility trailer sales business. I believe they got them from Redneck Trailer Supply. I plan on painting them Chevy "Hugger Orange". :)
Alaskan Benroy build journal: viewtopic.php?f=50&t=61738
ratrod71
Re: Alaskan Benroy
Postby dales133 » Wed Sep 09, 2015 7:34 pm
Havnt decided on mine yet but black i think
dales133
Re: Alaskan Benroy
Postby ratrod71 » Wed Sep 09, 2015 7:41 pm
Never can go wrong with black! Always classic. Bryan
ratrod71
Re: Alaskan Benroy
Postby ratrod71 » Wed Sep 09, 2015 10:00 pm
Removed the temporary screws from the roofs 1/8" plywood. Then took a router and trimmed all the edges and opened up the roof vent hole.
ratrod71
Re: Alaskan Benroy
Postby KCStudly » Wed Sep 09, 2015 10:35 pm
Sweet! :thumbsup:
Re: Alaskan Benroy
Postby dales133 » Wed Sep 09, 2015 11:05 pm
Looking good
dales133
Re: Alaskan Benroy
Postby ratrod71 » Sat Sep 12, 2015 1:18 pm
Just wanted to post a helpful tidbit photo of the screws I used to fasten down the 1/8" plywood on the top while the adhesive was curing. The self drilling feature and large head desgn worked very well. I bought them at a local industrial supply store here in Fairbanks. Happy building, Bryan
ratrod71
Re: Alaskan Benroy
Postby ratrod71 » Sun Sep 13, 2015 8:41 pm
Finished coating the roof with "West System" epoxy. That completes applying epoxy to all the exterior surfaces. Next item on the agenda is the dreaded hatch. With fear and loathing I began. I made the first rib which will be the Master Rib. My intentions are to rough cut all the others and router them to the Master. I chose to use "Apple Ply" for the ribs which is a brand of hardwood plywood that has 15 plys. The kind owner of Superior Hardwoods here in Fairbanks made me a deal on it I couldn't refuse. I am hoping to reduce springback by using this type of plywood. I stole the idea for the scribe tool from this website. Thanks to whoever first put forward the idea. Happy building, Bryan
ratrod71
Re: Alaskan Benroy
Postby ratrod71 » Sun Sep 20, 2015 8:53 pm
Got all the hatch ribs identical and ready to start putting them into place. Pictures show them just in a mocked up position to make some final calculations.
ratrod71
Re: Alaskan Benroy
Postby ratrod71 » Sat Sep 26, 2015 4:51 pm
I have a hatch! Finished the framework for the hatch and so far so good. Major milestone for me. This was an area I was dreading. But slow and steady payed off. I am going to let the TiteBond III dry overnight then unclamp it to see what I have. Materials are... ribs made from 15 ply hardwood "Appleply", spars are mahogany, and the corner gussets where the latches will be mounted are poplar.
ratrod71
Re: Alaskan Benroy
Postby dales133 » Sat Sep 26, 2015 5:30 pm
Nice one
Not half as bad as you think is it
How are you skinning it and finishing it off?
dales133
Re: Alaskan Benroy
Postby ratrod71 » Sat Sep 26, 2015 7:13 pm
dales133 wrote:Nice one
I think I dwelled on it about 50 times more than it took to build. Kinda fun building it in retrospect. I plan on skinning it on the inside and outside with 1/8" birch plywood. Then .040 aluminum on the outside. Two slam type latches, and offset "T" molding. Inside will be Spar Urethane Varnish on the birch plywood.
ratrod71
Re: Alaskan Benroy
Postby tony.latham » Sat Sep 26, 2015 7:42 pm
Nice stout but light-looking skeleton.
Wood is good.
Re: Alaskan Benroy
Postby mediczach » Sun Oct 04, 2015 9:50 pm
This is exactly what I'm planning on doing, keep up the awesome work
mediczach
Re: Alaskan Benroy
Postby S. Heisley » Mon Oct 05, 2015 7:45 pm
...Sounds good to me! Your hatch framing looks excellent. :thumbsup:
