New conversion 10x6 cargo trailer
Postby jegrosso » Wed Sep 16, 2015 9:58 am
I am repurposing a 10x6 trailer for a conversion to a camper trailer. I have been using it for camping in for a couple of years now. After looking at all the wonderful ideas and projects on this forum I am ready to take this to the next level.
I know there is much info posted on here about this decision, but my first consideration is to stealth or not to stealth. Being stealth makes it easy to keep it simple and tidy. However, if I decide not to go stealth, it seems to open many more options.
photo 2-1.JPG (219.94 KiB) Viewed 3281 times
photo 3-1.JPG (190.98 KiB) Viewed 3281 times
photo 1-1.JPG (239.85 KiB) Viewed 3281 times
JG
jegrosso
Re: New conversion 10x6 cargo trailer
Postby jegrosso » Wed Sep 16, 2015 12:50 pm
First things first…have a little maintenance to do. This thing has been sitting outside under trees fir years. Looking worn and sprung a few leaks. Spent the day getting the molded goo off the seams. Started with a scraper and chisel. Too labor intensive and not getting it all. Attached a wire brush wheel to my 1/2" drill and made short work of it. Nice clean surface to reseal to. Didn't have time to take pics, but will next week when back home.
Have seen a lot of opinions/info about what to reseal the seams with…just have to decide…
Also some surface rust on frame, etc.
jegrosso
Postby jegrosso » Thu Sep 17, 2015 8:04 am
Has anyone had good luck with the Eternabond tape sealer?
Seems too good to be true…means it usually is..
JG
jegrosso
Postby hankaye » Thu Sep 17, 2015 9:41 am
jegrosso, Howdy;
It's kinda of an RV industry standard repair material, used on the rubber (EPDM),
roofs.
Unless you dug the sealant out from between the shoulders sections (connects
roof to sides), you can use some tube type sealant (caulk), or just paint it with;
http://www.homedepot.com/p/Henry-4-75-G ... lsrc=aw.ds
Dual purpose, seals and keeps the interior cooler in the Summer, ... or both.
hank
hankaye
Postby Doublacola » Thu Sep 17, 2015 2:32 pm
Hello and good luck with your conversion.
It seems cheaper to go stealthy and there should be less work involved but I would only do it if needed to. Windows would definitely make the space feel larger.
jmho
Rich
Doublacola
Postby McDave » Fri Sep 18, 2015 12:52 pm
I like the stealth concept, but it would be nice to be able to see who/what is outside your trailer. :shock:
McDave
Images: 412
Postby jegrosso » Fri Sep 18, 2015 3:37 pm
McDave wrote:I like the stealth concept, but it would be nice to be able to see who/what is outside your trailer. :shock:
Maybe a wireless camera mounted outside the trailer with a monitor inside…?
But yes, stealth would be more simple and cheaper.
JG
jegrosso
Postby DustinS » Fri Sep 18, 2015 11:57 pm
JG
For this application, I'd go for a wired camera. Keep it cheap and simple, you don't really need the distance part of wifi cams.
DustinS
Postby Doublacola » Sun Sep 20, 2015 8:40 pm
A couple of simple door viewer's installed around the trailer works. Cheap and just drill a small hole.
Rich
Doublacola
Postby McDave » Sun Sep 20, 2015 9:56 pm
@ Doublacola,
That's a perfect solution. I'm using that!
smartypants...
McDave
Images: 412
Postby jegrosso » Mon Oct 12, 2015 4:02 pm
photo 2-3.JPG (199.18 KiB) Viewed 2620 times
photo 4-1.JPG (214.01 KiB) Viewed 2620 times
photo 1-3.JPG (229.06 KiB) Viewed 2620 times
Was able to get all the seams clean with a drill and wire brush wheel. Have decided to go with 6 inch Permabond Alumibond. worried about it bridging the gaps and laying down over the ridges where the pieces of the roof meet. The guy at the roofing supply store seemed to think there would be no problem with it bridging the gaps as long as I applied good pressure to the tape while putting it down.
He seemed to think the tape was a way better solution than sealant…
JG
jegrosso
Postby jegrosso » Mon Oct 12, 2015 4:05 pm
Also, the aluminum roof is a little dented and bent up…no rust though. Planning on inserting 1/4" plywood on the interior between the aluminum roof and the bracing on the inside to straighten it out and support it a little.
JG
jegrosso
Postby AZ_Desert_Rat » Mon Oct 12, 2015 4:51 pm
jegrosso wrote:I know there is much info posted on here about this decision, but my first consideration is to stealth or not to stealth. Being stealth makes it easy to keep it simple and tidy. However, if I decide not to go stealth, it seems to open many more options.
JG
I never thought much about the stealth idea and even with the windows, TV antenna, and awning, people do not realize it is a camper inside ... I did not try to hide anything ... 120 vac plug, grey water drain, propane tank, battery box, in addition to the windows, awning and TV antenna!!
I took it to a swap meet this last weekend (Got there a day early and camped over) and when folks looked inside they all seemed to be amazed that it had a galley, etc.
:o
Happy Camping & Building,
John (JC)
The Arizona Desert Rat 6x10' Cargo Conversion
The FunFinder a 19' Toy Hauler
An AZ Desert Transplant
Gallery: gallery/album.php?album_id=3168
AZ_Desert_Rat
Images: 55
Users browsing this forum: Google [Bot] and 3 guests
