#1
Re: #1
Postby ghcoe » Sat Sep 26, 2015 7:29 pm
Then of course the worst part, the bottom.
Bottom
Bottom #2
Bottom #3
George.
ghcoe
Re: #1
Postby ghcoe » Sat Sep 26, 2015 10:52 pm
Well I was getting things ready for canvasing the top tomorrow morning. As luck would have it the other HF drop cloth has the seam length wise :roll: . The stiching is also a lower quality, although the canvas seems to be the same so I will be able to use this for other applications inside. I hoped that I did not get one of the last of the other drop cloths. It has been over a year since I purchased these drop cloths. Made a run to HF and found that indeed they did have the drop cloth I needed. I could tell by the stiching and the tread used. So if you need canvas that has a 9'x6' clear area look for the HF drop cloth with a tight stich in the edges. The tread is also shinny, and all edges are finished. :thumbsup:
The other drop cloth, the stiching is loose and the thread is not shinny and is similar in color as the canvas. Also, only two ends are finished. The other ends are just cut canvas :roll: .
George.
ghcoe
Re: #1
Postby OP827 » Sat Sep 26, 2015 11:54 pm
Your trailer bottom canvas work is perfect, again!
OP827
Images: 414
Re: #1
Postby KCStudly » Sun Sep 27, 2015 12:37 am
Really nice canvas work! :thumbsup:
Re: #1
Postby GPW » Sun Sep 27, 2015 6:24 am
Neatness does count !!! :thumbsup: 8)
Re: #1
Postby dales133 » Sun Sep 27, 2015 6:28 am
Looking good. Verry neat edges
dales133
Re: #1
Postby GPW » Sun Sep 27, 2015 6:41 am
Just a thought about protecting those Neat edges .... the floor to wall join and under is an area that seems to see and collect a lot of water (around here anyway) ... and the canvas under the floor MUST be completely and thoroughly saturated and waterproofed... as well as the “reinforcing strip" underneath it (or on top) ... Current thinking is we would be better off with some kind of really simple drip edge that would channel any water down and away from the bottom of the floor ...
Any ideas about that ??? :thinking:
Re: #1
Postby dales133 » Sun Sep 27, 2015 7:10 am
GPW wrote:Just a thought about protecting those Neat edges .... the floor to wall join and under is an area that seems to see and collect a lot of water (around here anyway) ... and the canvas under the floor MUST be completely and thoroughly saturated and waterproofed... as well as the “reinforcing strip" underneath it (or on top) ... Current thinking is we would be better off with some kind of really simple drip edge that would channel any water down and away from the bottom of the floor ...
Here you can get a 40mm pvc angle about 4mm thick that is realy tough stuff .
Something like that if you could find a glue to stick to it would make a good edge.
I plumbers pipe glue or polyurathane adhesive would probably work...just a thought
dales133
Re: #1
Postby Wolffarmer » Sun Sep 27, 2015 7:55 am
There is a PVC glue. Really thought stuff. I do not know if it is in Home Depot and/or Lowes. Or local hardware stores. Around here I can easily get it from an Irrigation shop. Lots of them here in this agriculture area.
Wolffarmer
Images: 309
Re: #1
Postby dales133 » Sun Sep 27, 2015 7:56 am
Yea same stuff used for glueing pvc pipe together.
Incredibly fumey and goes off like a rocker.
dales133
Re: #1
Postby GPW » Sun Sep 27, 2015 8:17 am
I’m just trying to think of something Simple ... :thinking:
Drip edge.png (20.99 KiB) Viewed 11007 times
Re: #1
Postby dales133 » Sun Sep 27, 2015 8:19 am
You could use aluminium flat bar to do that
dales133
Re: #1
Postby ghcoe » Sun Sep 27, 2015 9:43 am
Even running a bead of caulking along the bottom edge would work to create a drip edge.
George.
ghcoe
Re: #1
Postby GPW » Mon Sep 28, 2015 8:09 am
Thanks Guys , you inspired me to re-visit this idea .... a Canvas drip edge :o ... I can either glue or sew a fold onto a piece of canvas, and just glue it over the other skin ... Simple , but It would seem necessary to completely WATERPROOF the completed assemblage .. Cheap, flexible , and easy to replace ... Not difficult to make , perhaps gluing between two wooden blocks as depicted. :thinking:
Re: #1
Postby ghcoe » Mon Sep 28, 2015 9:29 pm
Did not get time to update last night.
I got the canvas draped over the top and allowed for shrinkage of about 6".
Draped
Then I folded the canvas up in about 10'" folds so I could unfold as a went.
Folded
Worked fairly well except once I got to the curve in the roof I realized that 6" allowance at the bottom was not enough :roll: . Too late now, so I finished it out. Should have allowed for 12"
A little short
George.
ghcoe
