Talia62 wrote:I can't speak for the use in trailers, since I haven't built one yet. But in home repair or cabinet building, poplar is a little harder and more dent-resistant than pine.
Micro469 wrote:DON'T use poplar anywhere water can get to it. Trust me, I know.....I used poplar on outside trim, and found when it got wet, it really sucked up the water, and then turned to mush as dry rot set in. Had to replace/repair my hurricane hinge because of that.
It looks like most people use poplar for framing. What makes it better than pine? I had 50 2x4x8's
noseoil wrote:
I used red oak for both the hatch spars (cabin side & hatch side) for two reasons. First, it's much stronger & more dense. It takes & holds fasteners better than a softer wood like pine or poplar. Second, it is typically more resistant to rot than a softer wood. Keeping the water out is the first way to keep the wood intact, once it's in the wood, things become different. White oak would be better than red oak, but red is what I had at the time, so that's what I used.
