by Redneck Teepee » Mon Oct 05, 2015 9:59 pm
KCStudly wrote:Wow. In fact you are seriously under thinking this.
The hole in the spring is strictly intended to be an alignment pin to keep the axle from shifting off of the perch. The perch plays a critical roll of spreading the suspended load over a larger portion of the spring. The u-bolts play a critical roll of clamping a relatively large portion of the spring down to the perch. Without this relationship the spring would flex at the alignment hole and would quickly crack thru due to the hole being a stress riser (a place for a failure to start).
Drilling a hole thru the axle at the critical reaction load point of the spring is ill advised.
Using generic all thread for any critical suspension fastener is seriously ill advised.
Do it right. Protect yourself and those around you.
Have new perches welded on to the other side of your axle; if necessary, rebuild your spring packs with the alignment pin reversed; and use new u-bolts at reassembly.
This is very good advice given by K.C. 100% accurate in my opinion ..........we must always remember that it has to be safe, safe for all, including John Q. Public out on the road.
![Frightened :frightened:](./images/smilies/frightened.gif)
