Strop wrote:Dale, which Sika adhesive did you use and why?
I used several variants but mostly 11fc.
11fc is incredably flexable with a realy high bond strength joining dissimilar materials.
I used a biy of 221 assembly adhesive as well but its a bit costly.
Sellys armourflex is another realy good adhesive verry similar to 11fc.
I forgot what i was suposed to send you information wise mate youll have to refresh my memory.
Have you started your build yet?
Thanks KC glad you aprove it means alot.
I got the aluminium sheets installed today but im not realy happy with the front join.
To make the sheets work i had to join it right on the apex of the front radius and the tensions left it sitting up a little.
Its sealed and isnt an issue it just annoys me.
I might try to find some trim to cover it.
