Has anyone tried TotalBoat Penetrating Epoxy?
Postby sned » Wed Oct 14, 2015 12:52 pm
sned
Re: Has anyone tried TotalBoat Penetrating Epoxy?
Postby dogscats » Wed Oct 14, 2015 1:06 pm
I been told . The two are the same. Rhino Linings Deep Seal Epoxy with Hardener 3163 with thinner with there logo .
TODAY IS THE OLDEST YOU'VE EVER BEEN,
YET AT THE SAME TIME, THE YOUNGEST YOU'LL EVER BE,,, SO MAKE THE BEST OF IT WHILE YOU CAN, AND ENJOY THIS DAY WHILE IT LASTS
dogscats
Images: 20
Postby aggie79 » Thu Oct 15, 2015 5:15 am
The Amazon description said it had no VOCs. I haven't used the product but I have used CPES. CPES is about 2/3 VOCs by volume, so much so that you should wear a respirator with organic cartridges when applying it.
Postby sned » Fri Oct 16, 2015 5:00 pm
Would you say it's good to go to use on our TD's?
sned
Postby klhoush » Sat Oct 17, 2015 1:28 am
No. Are you painting your teardrop with Rhino Liner?
Google up Smith and Co. Steve Smith. CPES is not like standard epoxies. Don't be penny wise, pound foolish.
klhoush
Postby tony.latham » Sat Oct 17, 2015 12:52 pm
The Raka 127 (thin) epoxy is great and much cheaper. It certainly soaks into the top surface of baltic birch. Their 3-quart kit will do a teardrop.
http://store.raka.com/3quartkit.aspx
Postby dogscats » Sat Oct 17, 2015 1:17 pm
Rhino Line make more than bed liner . One co get it from Copone then adds thinner then puts it in there cans there 2 thinner that can be used
dogscats
Images: 20
Postby sned » Sat Oct 17, 2015 4:45 pm
Will be painting with marine paint. Was more attracted to the non VOC's more then the price but if Smith CPES is still the recommended product then that's what I'll do.
sned
Postby klhoush » Sat Oct 17, 2015 8:15 pm
If you will be storing the teardrop indoors it would last for many years with house paint on it.
The CPES can expand and contract at the same rate as the wood so it won't crack and fail anytime soon. I have been using it for years in the construction industry with no failures.
Kurt
klhoush
Postby robc in wi » Mon Oct 19, 2015 10:58 am
Hi, I'm in the planning stages. Is this type of epoxy used as an exterior sealant after the staining (assuming it's a woody)?
robc in wi
