Preshrunk canvas question
Postby lrrice » Tue Oct 20, 2015 12:46 am
I've been searching the forums and haven't found a definitive answer. Do you have to preshrink? I can't find where anyone had disastrous results, just fear of bad results. It seems to me that the canvas getting tighter would be a good thing. So if you left extra and/or firmly attached the edges (I'm going over wood and could put in temporary staples) would that not work or am I missing something?
lrrice
Images: 7
Re: Preshrunk canvas question
Postby dales133 » Tue Oct 20, 2015 5:26 am
It depends alot on the canvas how much it will shrink... or so i was told making enquiries,the drill canvas i used (diagonal weave)
Only shrinks around 2 -5%
Some other canvas can shrink more like 25%plus.
I preshrunk mine but only by wetting it down with water and letting it dry out in the sun so it would still have some shrinkage left to do.
Im no expert but i asked alot of questions here and at canvas suppliers.
Hope thats of some help
dales133
Postby GPW » Tue Oct 20, 2015 6:07 am
Consider this , even if canvas is pre-shrunk , can it not be stretched again when applied wet , and then shrink again ... :thinking:
Postby Talia62 » Tue Oct 20, 2015 1:34 pm
GPW wrote:Consider this , even if canvas is pre-shrunk , can it not be stretched again when applied wet , and then shrink again ... :thinking:
It won't stretch out to its original size, though.
Talia62
Postby tac422 » Tue Oct 20, 2015 8:30 pm
When I did the Big Pink, I did not preshink the canvas on the sides, and it worked out great.
On the top, I preshrunk by wetting it, and that also worked out great. I couldn't really tell the difference either way.
tac422
Postby ukewarrior » Tue Oct 20, 2015 8:45 pm
I preshrunk my canvas.
I am glad I did. I hardly shrank in the width, 72" to 71", but it shrunk a lot in the length. 10 feet became 8.5 feet.
There is no way I wanted a down the road issue with the canvas shrinking once on the tear.
It doesn't take any time, so why not?
ukewarrior
Postby GPW » Wed Oct 21, 2015 6:37 am
Some shrinking is Good , it tightens up the bond between foam and canvas .... just not too much ... :thinking:
Postby rowerwet » Thu Oct 22, 2015 6:50 pm
I did not pre-shrink the cheap drop cloth canvas on either tear.
rowerwet
Images: 521
Postby lrrice » Sat Oct 24, 2015 10:09 pm
Thanks for the replies. Guess I'll play it by ear. Not really looking forward to trying to wash and iron that big of a piece of material.
lrrice
Images: 7
Postby GPW » Sun Oct 25, 2015 6:07 am
As we found , the real trick using un-shrunk canvas was to leave enough extra material on the ends so you can trim it when it’s dry ... If you fit/cut it first , it may shrink beyond where it’s supposed to ...
Postby ghcoe » Sun Oct 25, 2015 8:46 am
GPW wrote:As we found , the real trick using un-shrunk canvas was to leave enough extra material on the ends so you can trim it when it’s dry ... If you fit/cut it first , it may shrink beyond where it’s supposed to ...
Yeah......what he said. :thumbdown:
Too short.....
George.
ghcoe
