go ahead, call me crazy !
Re: go ahead, call me crazy !
Postby dave campbell » Sun Oct 04, 2015 9:55 pm
still a very slow grind on project Y. work, weather, and lack of hands ---but still fiddle-faddling with rivets. i had to modify the rivet hammer because the rivet tops were so small the hammer would have done nothing but dent the aluminum. i stuck the bit on the lathe and took a grinder to it as it spun--then touched up the dish with a dremel. i found that the slightest imperfection transfers right onto the rivet-cap. also----air pressure is very important. it's easy to tell which rivet i drove with the highest pressure (about 100 psi). the nicest looking one was set with about 70 psi, and after i practiced a few times. they are so small that the slightest error in angle of approach or a heavy trigger finger results in ugliness.
here's the rivet hammer
rivet tool orig.JPG (50.68 KiB) Viewed 2453 times
here it is after some fixin
rivet tool mod.JPG (31.65 KiB) Viewed 2453 times
guess which is my first attempt ?
rivet test.JPG (62.17 KiB) Viewed 2453 times
:beer:
renaissance man-----MUST....MAKE......EVERYTHING !! (wife interjects here---"EXCEPT MONEY !")
dave campbell
Postby Greg M » Mon Oct 05, 2015 7:17 pm
For me it would be the left one. Then I'd get cocky and do the lower right ;)
Greg M
*Geek Extraordinaire
Images: 85
Postby sincere01 » Tue Oct 06, 2015 8:12 am
Greg M wrote:For me it would be the left one. Then I'd get cocky and do the lower right ;)
Ditto
Cheers,
Scott
My build thread: http://tnttt.com/viewtopic.php?f=50&t=63853
sincere01
Postby dales133 » Tue Oct 06, 2015 10:05 am
Another option for cutting /shaping your aluminium that you didn't mention would be a trim router with a bearing bit around a template.
Ive been using one recently with google results.
I see your a tiler too, cool
dales133
Postby dave campbell » Thu Oct 22, 2015 11:42 pm
dales133 wrote:Another option for cutting /shaping your aluminium that you didn't mention would be a trim router with a bearing bit around a template.
yup a tiler---45 years old and still grovelling for money !! been tiling for almost 25 years now. i do have a router, but have never really used it. i prefer grinders and drills. not sure why i never got into the router but it's there when i'm ready......on the tile front, and i'll try not to muddy up the build thread again---here's where i'm at with it these days around the house--
the 'goth mahal'.....step out the bedroom door and i'm under that light.
tile 1.JPG (53.22 KiB) Viewed 2284 times
the back deck.
tile 2.JPG (66.85 KiB) Viewed 2284 times
the 'barffice" it's an office--it's a bar
tile 3.JPG (44.61 KiB) Viewed 2284 times
and holy moly i've been away for so long that i dropped onto page two !!
:beer:
dave campbell
Postby dave campbell » Thu Oct 22, 2015 11:59 pm
finally a little progress-----
i guess my brain had to chew VERY silently on this phase. yesterday i felt the first glimmers of trailer energy bubbling up from the ground and today the massive shadowy hand of trailer god reposes before me. will it grab me from the safe confines or will i slip through it's grasp for a while longer ?
that's GE silicone 2. good stuff i think. not much more to say---3/32 holes--deburred. 7/8 spacing. about the same from the edge
laid a bead.JPG (42.01 KiB) Viewed 2400 times
very light anodizing comes off and is a good indicator of set-ness. great silicone placement--it spread well in all directions although less cleanup along the edge is preferable
about three quarters of the way down, the skin will be curling under the chassis. not apparent here are the five or six places i screwed the skin to the frame---either end in the cut-off zones and the top edge---where the hole will be covered if it is not removed. also happens to be where the skin and frame touch. i will remove these screws when the skin can drape over the spine, and re-consider the anchor points
row 3.JPG (33.5 KiB) Viewed 2400 times
:beer:
dave campbell
Postby dave campbell » Fri Oct 23, 2015 12:07 am
last shots of the night
sin inside outside.JPG (46.85 KiB) Viewed 2399 times
lots of anchors for the spray on insulation to grab
skin inside.JPG (45.68 KiB) Viewed 2399 times
:beer:
dave campbell
Postby dales133 » Fri Oct 23, 2015 12:31 am
Good stuff dave and love the tiling.
Did a fair bit of out there tiling mysef.
dales133
Postby S. Heisley » Fri Oct 23, 2015 10:23 am
You are quite talented! :thumbsup: Thanks for sharing! :applause:
Postby KCStudly » Sat Oct 24, 2015 8:02 pm
The tile work looks great. I like the snow flakes (small white squares) on the winter deck scene, and the decorative treatment with the hubcaps. :thumbsup: :thumbsup:
Looks like you are over the hump on the trepidation moving on with the very complex stage of covering. Totally understand that issue; I get that, too.
My current distraction is flying gourds. :R :R :? :D
Postby OP827 » Sat Oct 24, 2015 11:25 pm
Great looking tile work! And it looks like you will be an expert with setting the rivets before you know it. I am really looking forward to see some closeup of final riveted surface on outside skin. Love it! :thumbsup: :applause:
OP827
Images: 414
Postby dave campbell » Tue Oct 27, 2015 9:53 pm
dales133 wrote:Good stuff dave and love the tiling.
thanks dales---still tiling ?
:beer:
dave campbell
Postby dave campbell » Tue Oct 27, 2015 9:54 pm
S. Heisley wrote:You are quite talented! :thumbsup: Thanks for sharing! :applause:
thanks heisley !!
dave campbell
Postby dave campbell » Tue Oct 27, 2015 9:55 pm
KCStudly wrote:The tile work looks great. I like the snow flakes (small white squares) on the winter deck scene, and the decorative treatment with the hubcaps. :thumbsup: :thumbsup:
ok---i'll bite---what the heck is a flying gourd ?
:beer:
dave campbell
Postby dave campbell » Tue Oct 27, 2015 9:56 pm
OP827 wrote:Great looking tile work! And it looks like you will be an expert with setting the rivets before you know it. I am really looking forward to see some closeup of final riveted surface on outside skin. Love it! :thumbsup: :applause:
thanks op8----i'll post a close-up as soon as i can rivet a section good looking enough to fill a photo :beer:
dave campbell
