5x td build
5x td build
Postby Kololikova » Fri Nov 13, 2015 11:01 pm
Hello my name is Chris and this is my new build thread for my 5x8 teardrop which is loosly styled along the lines of the Oregon trail r tds.
So far I have been busy welding up the frame and have been constructing the axle today. I am from New Zealand by the way
Cheers Chris
Kololikova
Re: 5x td build
Postby Kololikova » Fri Nov 13, 2015 11:10 pm
Here's a progress pic
Kololikova
Re: 5x td build
Postby greygoos » Sat Nov 14, 2015 8:13 am
Good luck Chris. i hope the tear comes out exactly as planned
greygoos
Re: 5x td build
Postby felixx » Sun Nov 15, 2015 2:18 am
Good to see a start
If you are up chch way at all, drop in and have a peek at mine
I dont THINK I will be going as far south as Dunedin, maybe timaru this summer
felixx
Images: 22
Re: 5x td build
Postby rebapuck » Sun Nov 15, 2015 12:56 pm
Get those wheels vertical!
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Re: 5x td build
Postby Kololikova » Sun Nov 22, 2015 12:28 am
Did some more work on the frame today. Axle all finished and bolted up to springs. Just need tyres and bolt on the coupling and it's a rolling chassis.
Chris
Kololikova
Re: 5x td build
Postby Kololikova » Sat Mar 05, 2016 11:47 pm
So here is an update. Have not been able to do much as was recently diagnosed with a major illness but back to it now.
Just done a full coat of rust arrest primer and ready for final coat soon, then I will start running the electrical cables.
Cheers
Chris
Kololikova
Re: 5x td build
Postby jmascioni » Sun Mar 06, 2016 12:42 am
Hello Chris,
Looks like you are off to a great start. I am looking forward to watching your build come together. I am new here as well and about to start on my own once the weather co-operates.
Sorry to hear about your illness, but don't let it get you down. We can overcome anything that stands in our way with perseverance.
jmascioni
