A woody tiny-trailer for my first build!
Re: A woody tiny-trailer for my first build!
Postby drshoe » Tue Nov 17, 2015 12:02 am
Weekend 9
Finally got a chance to get back to work on the trailer, even if we didn't get much done.
We had a tongue made by a local welding shop. I sent plans out to 7 local shops, only 2 responded and only 1 was willing to do it. All I needed was a few holes drilled and some anti-crush sleeves welded in. Guess it's time to take a welding class.
20151107_145127_resized (640x480).jpg (184.58 KiB) Viewed 1905 times
20151107_145150_resized (640x480).jpg (221.13 KiB) Viewed 1905 times
We also installed a grate underneath the air-conditioner to reduce the amount of road splash entering that compartment and installed the back panel with a utility door to access the power center.
20151108_135237_resized (480x640).jpg (203.22 KiB) Viewed 1905 times
drshoe
Postby drshoe » Tue Nov 17, 2015 12:04 am
Weekend 9 continued
We also installed the fenders and attached the lights. The lights have actually been removed again as they need to be extended out a few inches further.
20151108_111847_resized (480x640).jpg (208.44 KiB) Viewed 1905 times
drshoe
Postby drshoe » Tue Nov 17, 2015 12:10 am
Weekend 10
Had to get a smaller coupler - got that installed and moved the tongue jack.
IMG_20151114_165322_427 (2) (640x480).jpg (162.51 KiB) Viewed 1905 times
Trimmed the bottom:
20151114_180107_resized (640x360).jpg (90.7 KiB) Viewed 1905 times
Trimmed the corners and installed vents covers over the galley exhaust holes:
20151114_192837_resized (360x640).jpg (101.64 KiB) Viewed 1905 times
drshoe
Postby drshoe » Tue Nov 17, 2015 12:16 am
Weekend 10 continued
Added a vent cover for the air conditioner exhaust also:
20151114_192916_001_resized (360x640).jpg (110.71 KiB) Viewed 1899 times
Added some decorative trim stripes:
20151115_153429_resized (360x640).jpg (113.97 KiB) Viewed 1899 times
And trimmed the seams:
20151115_153403_resized (360x640).jpg (128.72 KiB) Viewed 1899 times
We are so close to done! Unfortunately the weather is such that our plans to clear coat with spar varnish will have to wait for spring. Otherwise, the remainder will be done over Thanksgiving break.
drshoe
Postby noseoil » Tue Nov 17, 2015 7:49 am
Looking really good! Nice job on the trim & details.
137905
noseoil
Images: 670
Postby Woodbutcher » Tue Nov 17, 2015 8:07 am
Nice work, you are in the home stretch now!
Woodbutcher
Postby rebapuck » Wed Nov 18, 2015 4:46 pm
Good idea on the carved decorative trim.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby drshoe » Wed Dec 02, 2015 7:10 pm
Weekend 11
Installed the tail lights and side indicator lights.
20151128_195849_resized (640x360).jpg (147.38 KiB) Viewed 1748 times
20151128_195836_resized (640x360).jpg (118.24 KiB) Viewed 1748 times
20151128_195635_resized (360x640).jpg (145.11 KiB) Viewed 1748 times
drshoe
Postby drshoe » Wed Dec 02, 2015 7:13 pm
Weekend 11 continued
Installed stabilizer jacks. On the rear they fold down and extend laterally:
20151128_195722_resized (640x360).jpg (115.72 KiB) Viewed 1748 times
20151128_195755_resized (360x640).jpg (152.95 KiB) Viewed 1748 times
On the front, the A-frame tongue prevented that so they point forward, with a slight angle laterally:
20151128_195825_resized (640x360).jpg (114.13 KiB) Viewed 1748 times
drshoe
Postby drshoe » Wed Dec 02, 2015 7:17 pm
Installed a vent cover:
20151128_195903_resized (640x360).jpg (108.08 KiB) Viewed 1748 times
Some trim around the hatch lid and camlocks to keep it shut:
20151128_195706_resized (640x360).jpg (117.75 KiB) Viewed 1748 times
And an important kitchen accessory:
20151128_195622_resized (360x640).jpg (91.86 KiB) Viewed 1748 times
drshoe
Postby drshoe » Wed Dec 02, 2015 7:25 pm
We fashioned a battery box from a weatherproof file box, some grommets and a vinyl tube for a vent, we put putty where the cables meet the grommets just to ensure they were sealed. The + lead and one - lead go to the PD4045, the other - lead goes to the DC ground block:
20151128_200050_resized (640x360).jpg (126.4 KiB) Viewed 1744 times
The DC system is grounded to trailer frame by the other large gauge wire running from the ground block to the same contact point as the AC system:
20151128_195954_resized (640x360).jpg (145.98 KiB) Viewed 1744 times
We painted the countertop with "scrubable paint" we'll see how long it lasts.
20151128_195933_resized (640x360).jpg (85.04 KiB) Viewed 1744 times
drshoe
Postby drshoe » Wed Dec 02, 2015 7:31 pm
We installed a shelf in the galley, it's not a ton of space but is a bit taller than what you can see in the picture, and it's big enough to get a coleman stove into:
20151128_195515_resized (640x360).jpg (120.79 KiB) Viewed 1740 times
And with all the lights and the camera flash off, you can see we've got plenty of light to cook by:
20151128_195544_resized (640x360).jpg (89.38 KiB) Viewed 1740 times
We still aren't done as not everything we needed arrived in time. We have a half dozen trim pieces yet to install, I decided to order some of that black plastic continuous piano hinge to trim the odd angles of the body. I also had to order some nuts for the tongue, apparently 1/2" coarse Grade 8 nylock nuts are not in high demand.
That will be taken care of next weekend, I'll also be installing the tow kit on the wife's Dodge Caliber. If all goes well, we're going to be taking the trailer for a spin by the end of the weekend!
drshoe
Postby KCStudly » Wed Dec 02, 2015 8:40 pm
Looking good! :thumbsup:
I was wondering about the decision to run the chassis ground from the bus instead of directly from the battery. :thinking:
Postby drshoe » Wed Dec 02, 2015 11:05 pm
KCStudly wrote:I was wondering about the decision to run the chassis ground from the bus instead of directly from the battery.
Two reasons, it was convenient and it satisfies my current requirements (pun intended.)
It is good standard practice to run the chassis ground to the battery terminal. That way if you disconnect the bus from the battery, the chassis is still grounded.
At this point I haven't installed any type of general disconnect for the DC system; if I were to install a switch on the battery to bus connection then I would most certainly bring the chassis ground to the battery post.
drshoe
Postby drshoe » Fri Dec 18, 2015 11:00 am
Weekend 12
It's done! for now...
A sketch from before we started:
IMG_20151208_203104_411 (2) (640x448).jpg (109.63 KiB) Viewed 1610 times
and pictures:
20151206_153114_resized (360x640).jpg (130.7 KiB) Viewed 1610 times
20151206_153149_resized (640x348).jpg (159.46 KiB) Viewed 1610 times
drshoe
