The Astroliner
Re: The Astroliner
Postby Atomic77 » Tue Nov 17, 2015 3:26 pm
roamer wrote:I want to build one myself. A previous coworker made one. It would cook you out of his shop. He made it from an old hot water heater tank.
I have an large supply of free waste oil from an automotive shop. FREE HEAT! If I only had more time!
I actually have used it to power my Cummins. I try to keep it to 25% when I do, waste to diesel. It is an oil burner after all.
He fired it last night. It burned for about an hour and a half and only used a little over an inch of oil out of the 5 gallon bucket. Temps at the stove were between 400-700 degrees depending where you checked. We have located a couple farmers that have several 55 gallon barrels that need gone. At the race shop alone I have 300 gallons of used gear oil and turbine oil. You're right... Free heat.
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Re: The Astroliner
Postby roamer » Tue Nov 17, 2015 10:38 pm
I worked at a dealership in NW Montana that used a waste oil boiler for ALL the hot water and radiant heat in the entire dealership. It gets cold there. They stored up to 3500 gallons of waste at a time. We always had to pay to have it hauled off (we used less than we needed). Makes one wonder about the bigger problem. :NC
Dave
If you think you can't, you won't
138765
roamer
Images: 25
Re: The Astroliner
Postby Atomic77 » Wed Nov 18, 2015 12:09 pm
Here in Indiana, we used to have to pay to have waste oil hauled away. Now waste oil reclaimers will pay you to haul away your waste.
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby Vedette » Wed Nov 18, 2015 12:28 pm
Okay Michael
You have got the shop warm....now get back to work! :R
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: The Astroliner
Postby Atomic77 » Wed Nov 18, 2015 12:30 pm
I've been working on the minutiae of the body work, Brian... I'm in my wheelhouse now. The carbon fiber has gone away and the lines are crisp and straight! I'm very pleased with the result and so close to primer. I'm ready to see this thing all one color!
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby dales133 » Wed Nov 18, 2015 4:27 pm
Looks great mate
dales133
Re: The Astroliner
Postby Atomic77 » Wed Nov 18, 2015 6:28 pm
Thanks man. I heard you were having fires over there. No where near you I hope?
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby Vedette » Wed Nov 18, 2015 8:25 pm
Yes, isn't he primer stage wonderful after that always too long "Bodywork Period" :applause:
After seeing your helmet collection, we are all waiting to see your paint scheme for the sides. :twisted:
Keep going forward man! we are enjoying your build journal. :thumbsup:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: The Astroliner
Postby KCStudly » Wed Nov 18, 2015 8:30 pm
Nice straight lines. :thumbsup:
Re: The Astroliner
Postby MidTNJasonF » Wed Nov 18, 2015 8:52 pm
roamer wrote:I worked at a dealership in NW Montana that used a waste oil boiler for ALL the hot water and radiant heat in the entire dealership. It gets cold there. They stored up to 3500 gallons of waste at a time. We always had to pay to have it hauled off (we used less than we needed). Makes one wonder about the bigger problem. :NC
When I was still working as a Machinist I made several machined parts for one of the manufacturers of those commercial waste oil heaters. Mostly injector nozzle blocks from aluminum extrusion. They are remarkably efficient for what they are. If I had a shop of sufficient size that needed heating I would seriously consider getting one.
Wonderful craftsmanship in this build Atomic. I very much enjoyed reading through the progress so far. :applause:
MidTNJasonF
Re: The Astroliner
Postby Atomic77 » Wed Nov 18, 2015 9:09 pm
Vedette wrote:Yes, isn't he primer stage wonderful after that always too long "Bodywork Period" :applause:
Good Roads
Brian & Sandi
Brian you might have missed this but that collection of helmets was found on Pinterest. It was a test photo for a new app and inspiration for the paint scheme...
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby Atomic77 » Wed Nov 18, 2015 9:10 pm
Thank you and good to have you stop in
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby Vedette » Wed Nov 18, 2015 9:32 pm
Good Roads
Brian & Sandi
Oops! :oops:
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: The Astroliner
Postby dales133 » Thu Nov 19, 2015 2:12 am
Fires arnt near me but hot weathers headed this way now.
5 deaths the otherday and alot of property lost.
Gonna be a bad year for fires me thinks
dales133
Re: The Astroliner
Postby Atomic77 » Thu Nov 19, 2015 8:05 am
That's bad to hear, but take care of yourself mate.
Michael
The Astroliner
Atomic77
Images: 309
