drhill wrote:My teardrop is removable from my trailer. I don't have the luxury of space for an extra trailer and this set up has worked very well for me. Have a look in my album for pictures and feel free to ask any questions you want.
Don
drhill wrote:Below is what I had in mind if I want to be able to move the camper unit around in the garage when it is removed from the trailer. I would build two stands with a welded support at each end. It would function much the same as the stand you posted in your first post, but this would be built to be easy to disassemble to store against a wall or lay on the floor and park the trailer over the pieces. It is all about too much stuff and not enough space.
drhill wrote:The decking I used was 3/4" T&G fir plywood and yes, I used the scroll saw to cut notches around the inset stake pockets. You could go with a lighter decking material depending what you plan on hauling. I had a look at some of your posts from a couple years ago and I see you are, or at least were, towing with a Mazda 5. So keeping it light will be more important for you.
The floor of my camper is 2x4's laid on sides (1.5" in the vertical dimension) and 1/2" plywood over that. The spaces between the 2x4's are filled with foam glued in place. I didn't put any sheeting material on the bottom of the floor. It is all covered when it sits on the deck of the trailer. The 2x4's were overkill, 1x2s would work. But make sure you end up with some lumber, not just foam, over the stake pockets where you will be lifting the camper.
I didn't do a Build thread as I was building but posted some after at viewtopic.php?t=61318
I also see that you weld. I have another idea for stands for the camper when it is off the trailer, but it requires some welding. I'll sketch something up later and post it.
I have had this trailer about a year and a half now and have hauled at least 4 loads of firewood, 3 loads of bricks, a catamaran, a fridge, a load of shingles and loaned it out for a move. Wow. But I actually haven't hauled any dirt, sand, gravel or wood mulch -- yet. I tend to put my trailer to allot of use. On the plus side, I have logged about 47 nights camping with it.
Vedette wrote:Things that are up in the air have a further distance to fall.![]()
What kind if lift system are you going to use to lift this camper pod on and off of the trailer?
Vedette wrote:Regarding this concept my question has always been WHY???![]()
If it is going to cost more than a $100.00 to design, fabricate, or buy stands and a lifting system of a removable teardrop "pod" removal and storage system?????..........then why not buy a used utility trailer or even on of those cheap HF trailers to leave out in your side yard to haul whatever, whenever. And just build a normal teardrop with a removable tongue that you can push into the corner of you garage when not in service .
Way Simpler! Way Cheaper! And like ALL "Single Function" things, Way Better than any "Multi Purpose" gadget.
Remember trying to eat your camp meal at Boy Scout Camp with your cool Swiss Army knife rather than a simple knife, fork, and spoon? What a piece of crap!
Same principle applies here!
Good Roads
Brian & Sandi
