noseoil wrote:Back to square one again. Just thinking out loud about a plug-in heater. Too much load for too small a return.
I guess with shore power it would work OK, but a small 110v ceramic heater would be a better choice in general for a teardrop if there's power available. We used one briefly in Nevada on cold mornings in November. It worked really well with shore power, but was a bit of "overkill" due to the 1000 watts it was putting out. Didn't take long to take off the chill in the morning in such a small space.
Looks like the propane & water solution is better in terms of energy use, just a bit more complex to setup & run as a closed loop system.
noseoil wrote:Tom, it sounds like you must have access to some shore power at the site, yes? I like the idea of feeding some heat into the space from outside & the tent, simple & easy.
Having no condensation inside during cold weather would really be a plus. Ours was pretty wet inside on the glass when it was in the 30's at night. The walls & roof were fine, since it's well insulated, but the glass is wet after a night of sleep. We used a small ceramic heater with shore power in the morning in Nevada, but it will run you out after about 15 minutes of putting out heat in that small space.
That's why I was thinking about a 60 watt 12 volt ceramic model. I guess a 60 watt 110v light bulb would do the same thing & be cheaper to buy, that is, if you can still find them....
lrrowe wrote:I have memories of back in the early sixties of using a 150 watt bulb under the hood in those cold Adirondack winters to warm our engine block. It worked. The cars started.
