Outdoor reading lights
Anything electric, AC or DC
Re: Outdoor reading lights
Postby Tomterrific » Wed Dec 16, 2015 10:41 am
I'm surprised so few mentioned headlamps. Wife and I were with an outdoor club years ago and headlamps were by far the preferred light to read and task by. Hand held flashlights were used when folks needed a temporary burst of light while walking or locating. The problem of headlamps is when you look up at your partner you blind them. 8>(
Tt
Tomterrific
Postby kludge » Wed Dec 16, 2015 5:11 pm
You learn not to do that. :)
Love my headlamp!
kludge
Postby noseoil » Sun Dec 20, 2015 9:34 am
These are fairly "spendy" for a small flashlight, but they will clip onto a baseball cap & work for reading & working. My wife used one when we went into a lava tube up in Flagstaff for a "hike" last summer.
You don't need to spend $40 for a reading light, but they work well enough & last a long time with the single CR123 battery on low power. They also have a magnetic base & will function as a work light in a pinch at night or under the truck. They are small, compact & weigh next to nothing. No, I don't work for the company, just like this light!
http://www.amazon.com/Olight-S10-LED-Fl ... B0091QBCK6
Edit: Better deal from Amazon
http://www.amazon.com/Olight-S10-Flashl ... J6CEPXGTJR
137905
noseoil
Images: 670
Postby bdosborn » Sun Dec 20, 2015 9:28 pm
I made a removable 12V LED strip that hangs from the exterior trim for just the situation you've described- reading outside with a kindle:
Then there's that old favorite:
Images: 806
Postby Shadow Catcher » Sun Dec 20, 2015 11:51 pm
One of the items I ordered in the "shotgun" approach was an LED clamp light with a long enough goose neck that it can be clamped to the back of the chair and peer over the shoulder. It came a couple of weeks ago from China. I checked the wrong box and it has a European two pin plug, but since I plan on running it from 12VDC, I cut the plug which has the "driver" and hooked it up to 12V and it works fine. I will set it up with Anderson Power Poles.
Return to Electrical Secrets
