How much venting is required while charging? Would this work or will the hole works overheat? Do I leave the lid open? I want to mount this on my tongue
MtnDon wrote:The BD batteries method which is similar to the zomeworks 5.... I used 1/2" OD soft copper tubing inside a 1" copper pipe that is epoxied to the usual RV style plastic vent cover. . I'd show you but it is built in and hidden under the bed.
Your plan is probably alright. It just has theoretical problems under some temperature conditions. I only know of two cases of battery explosions. Both were owner / operator initiated; 1 by smoking and the other by installing a charge controller in the battery box. A relay spark probably initiated that one. The smoker lost partial vision in one eye, the other just ended up with a hole blown out the RV side.
