I think it can work well and can also be used via 1000W converter from a battery with solar. Please share your experience here if you did this kind of project. Thanks for your input
MtnDon wrote:Have you considered a 12/24 VDC Truckfridge like we have?
GuitarPhotog wrote:In general compressor fridges and AC units don't run well off inverters because of the large peak current demands when the compressor starts up. If the fridge draws 8A running, a 1KW inverter certainly won't cut it. You'll need twice that.
Search here on running a fridge off an inverter. There's a reason it's not done much.
<Chas>
OP827 wrote:MtnDon wrote:Have you considered a 12/24 VDC Truckfridge like we have?
No, I did not, thanks for the link. The fridge price seems to be quite good, i.e. it is comparable to 2000W inverter plus 115V mini fridge.
How do you like it?
Stainless wrote:I have spent hours and hours and hours researching an elegant, cost-effective solution to this question. I don't want to spend the money on a real 12 V Carnot fridge, and I don't want to monkey with the inverters and ridiculous electrical requirements an AC fridge in a DC trailer.
So far, it's been a disappointing battle. The best solution that I've found is to replace the 120 V compressor in a dorm fridge with a real 12 V compressor, but even those are tricky to find as an individual piece (and quite expensive, even if I was willing to blindly hand my credit card number over to an unproven overseas vendor). It would still be a minimum $400 solution, and that doesn't include the cost and nuisance of recharging the fridge with freon after the new compressor is soldered in. My garage is a house of horrors as testimonial of my love for tinkering, but that's too much for me to bet on the hope that there are no other hidden reasons why it won't work.
If you want to brainstorm, I would be happy to participate.
Users browsing this forum: tony.latham and 3 guests
