Have any of you seen this?
http://www.lowes.com/pd_75514-99899-755 ... 58448&pl=1
halfdome, Danny wrote:You may have to call someone in China to settle your beef with the poor quality plywood.
The last 10 years or so I've experienced plywood form the afore mentioned country, and others offshore, that will delaminate in the center of the sheet once you cut into a 3/4" x 48" X 96" sheet.
I've stopped buying Red Oak plywood from Lowes and Home Depot since it's all filled with knots on the B side and a few on the A side.
The A side should be knot & check free or it's not a premium grade of plywood.
Find an independent lumber yard and ask questions & check out the plywood before making a purchase.Danny
MtnDon wrote:"Top Choice", Premium Choice", etc. are simple marketing tools. Those words are not official grades.
I'm only being the messenger here; don't shoot me.
Unfortunately, almost all hardwood plywood sold in the USA and Canada is manufactured with type II adhesives. It is best described as making a somewhat water resistant bond between the plywood layers. Type I is what is required for exterior use of a hardwood plywood. Unlike softwood panels that are grade stamped on the worst side hardwood panels are seldom stamped. If you need exterior use then asking a knowledgeable person at the supplier is necessary. I always go with the thought that any hardwood plywood I see uses type II, sorta water resistant, glue.
Some hardwood plywood info. Hardwood plywood is considered an appearance product whereas softwood plywood is mainly graded as a structural product. Different rules apply to hardwood vs softwood.
That link to the Lowes product does state "Weather Exposure For interior use" so it is not really the fault of the product if the trailer was used outside.
"There is hardly anything in this world that some man cannot make a little worse and sell a little cheaper, and those people who consider price only, are this man's lawful prey. It is unwise to pay too much, but it's worse to pay too little. When you pay too much you lose a little money - that is all. When you pay too little, you sometimes lose everything, because the thing you bought was incapable of doing the thing it was bought to do. The common law of business balance prohibits paying a little and getting a lot; it cannot be done. If you deal with the lowest bidder, it is well to add something for the risk you run, and if you do that you will have enough to pay for something better"
John Ruskin (1819 - 1900)
VegasNick wrote:So this is an issue that I ran into with my teardrop. I used the Premium Choice, 3/4 Maple from Lowes. (about $50 a sheet) After about 6 months, I noticed a few cracks in the sides. They were very small but noticeable in the paint. So, I sanded the paint and primer off where I could see the small crack. As I started looking at how to repair it, I sanded some more and found what you see in the final photo. The wood is absolute junk, and the veneer if paper thin. Every place one of these cracks developed, there is a giant void underneath the veneer over a knot. I called Lowes and they pretty much told me that I should have bought better wood. at any rate, I am going to try to work through Lowes corporate till I get to the manufacturer and give them a freaking ear full. Had I paid attention, I would have seen all the other negative reviews for the same issue.
