Gluing Aluminum sheets
Postby JmsCaverly » Sun Jan 03, 2016 2:58 pm
I'm interested in hearing how everyone is adhering their aluminum sheets to their 'drops. I've done a lot of work with contact adhesive on countertops and I work rather comfortablely with it. But I want to see how others have completed this task. Or even pros and cons of my idea.
Come visit my build journal
139728 139588
viewtopic.php?f=50&t=63870
JmsCaverly
Images: 175
Re: Gluing Aluminum sheets
Postby noseoil » Sun Jan 03, 2016 3:26 pm
I just used contact cement to temporarily spot the panel in place. Made 2 blocks with saw kerfs in them to support the sheet at the bottom, painted a line of contact at the top edge on the trailer & the sheet & then aligned everything so I could spot the top edge. Mine is floated & held in place by windows, doors & trim. The aluminum will expand & contract with heat & cold (about 1/8" here in Tucson for the length), so I didn't want to create too much stress between the aluminum & the plywood under it.
The dissimilar materials won't work too well with the temperature changes we have here in the desert. We've had nights in the 20's this winter and daytime temps about 110 in the shade. Add some sunshine & you get a range of about 130 degrees difference. This adds up to quite a bit of movement as the seasons change.
137905
noseoil
Images: 670
Postby JmsCaverly » Sun Jan 03, 2016 3:37 pm
Tim now you've got me thinking. I live in the Sacramento area and with most of my camping being done up in Tahoe temp changes can be rather drastic not nearly as bad as Tuscon but still enough to cause issues. So did you just seal around the perimeter and call it a day? Do you think there will be issues with oil canning?
139728 139588
JmsCaverly
Images: 175
Postby dales133 » Sun Jan 03, 2016 3:44 pm
Only my roof and front is aluminium but i did the same as Tim.
The edge trim is all that holds mine on plus the sheet joins are screwed and glued together with sikaflex but arn glued to the drop itself
dales133
Postby halfdome, Danny » Sun Jan 03, 2016 6:28 pm
Check out this thread.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby JmsCaverly » Sun Jan 03, 2016 7:02 pm
Thank you sir that's what I was looking for I just couldn't find it.
139728 139588
JmsCaverly
Images: 175
Postby noseoil » Mon Jan 04, 2016 7:52 am
James, I do get some "oil canning" when it's hot outside, but it shrinks back up when night temps drop in the summer. My sides & roof were done at about 90f outside in the summer, so I figured it's about half way between hot & cold. Not really a big deal for me. I could have trimmed the sheet a bit at the edges, but figure with the butyl rubber tape & fasteners in the trim it will be good enough over time. So far, not a drop of water gets inside, except for condensation on cold nights on the inside window glass.
137905
noseoil
Images: 670
Postby linuxmanxxx » Wed Jan 06, 2016 11:06 am
I used 3M water based contact complete adhesion sealed waterproof and not a single issue or oil canning ever on 2 builds.
linuxmanxxx
Images: 10
Postby Gunguy05 » Wed Jan 06, 2016 1:07 pm
I used OSI Quad sealant at the edge, no glue. It is held in place by the trim. I do have some old canning on the top in the summer, but I have a window, a fan, and an attachment to s spar at a seam on the top. No issues on the sides whatsoever
Brian
Gunguy05
Images: 6
Postby rowerwet » Fri Jan 08, 2016 1:00 pm
Reading about one CT maker, the builder said they saw better results in the skins done in hot weather.
Railroad track is heated to over 100 degrees and then fused together, leaving it in tension.
Try skinning on a hot day / in a hot shop.
rowerwet
Images: 521
Postby DMcCam » Thu Feb 18, 2016 12:39 am
Grant Whipp advised us to use automotive vinyl roof contact cement. It works as a water barrier, glues the aluminum tight and yet allows for expansion. It's been two years of camping in the Sierra range and dessert with no issues at all.
All the Best,
Dave
DMcCam
Postby Shadow Catcher » Thu Feb 18, 2016 10:33 am
The sides of large truck trailers are often held on with 3M VHB tape and allowed to float some to keep it from oil caning.
