Board floors , not plywood ...
Re: Board floors , not plywood ...
Postby KennethW » Wed Jan 06, 2016 10:54 am
GPW wrote:Good points for both Plywood and boards , or even foam ... Guess it’s up to the builder to choose ... :thinking:
FYI, I’m only trying to promote different ideas here , so don’t get mad at me if you don’t agree... Simply post your views for consideration too ... ;) :thumbsup:
Me too. That is a lot of my post. It make people think outside the box. :twisted:
KennethW
Images: 82
Postby lrrowe » Wed Jan 06, 2016 10:59 am
Me too. That is a lot of my post. It make people think out side the box.
Althought not for this topic, I agree not to agree at times. Isn't this what it is all about....exchanging ideas and thoughs?
Bob
lrrowe
Images: 439
Postby GPW » Wed Jan 06, 2016 12:56 pm
Yeah , If we all thought the same , nobody would be thinking ... And we’d all likely still be building wooden trailers ... :frightened:
I apologize for my enthusiasm , but I just love the idea of building a comfortable , usable trailer for under $1000.00 ... And not requiring a shop filled with big tools to do it ... and then , there’s "the Ballast" ... :beer:
Postby rowerwet » Wed Jan 06, 2016 5:32 pm
I still don't see a better method than ply treated with epoxy or the mix.
rowerwet
Images: 521
Postby GPW » Wed Jan 06, 2016 6:09 pm
Best so far eh , but treated OSB isn’t so bad either , but even Heavier ... :o
We have to get the Marine plywood... That’s very pricy , but if it lasts ... :thinking: We know the foam will last a very long time ... can you imagine a hundred years from now and all the Vintage Foam trailers on the market , still camp-able ... :beer:
Postby alaska teardrop » Wed Jan 06, 2016 9:05 pm
Simple construction.
Lightweight.
Protected underside.
No wood rot.
Insulated floor.
:designing: Ideas, Fred
(1000th post)
alaska teardrop
Postby KennethW » Wed Jan 06, 2016 9:39 pm
That is close to what I did. My floor is painted canvas on the bottom with 2" EPS and FRP on the top. Very light, warm and will not rot. I would have to say I think it have about the same flex as 1/2 plywood. With metal on the bottom it would be like 3/4 plywood.
KennethW
Images: 82
Postby GPW » Thu Jan 07, 2016 7:58 am
You guys are definitely on to something here ... :thinking: :thumbsup: 8)
And with a little looking around we can get foam with greater density , making it even better as part of a composite floor ... The Blue /Pink foam we usually find is ~ 2 lb./cu.ft. Imagine how much stronger 4 or 6 lb foam would be... :D
Postby GPW » Thu Jan 07, 2016 8:12 am
The Dow site has lots of information ... Check out the "deckmate” foam ... http://building.dow.com/en-us/products# ... C0%7C0%7C0
Postby rowerwet » Thu Jan 07, 2016 6:01 pm
Price point for enough sq ft becomes the next question
rowerwet
Images: 521
Postby GPW » Fri Jan 08, 2016 1:44 pm
Well considering a really good sheet of specialized plywood might cost over $100 .00 now ....maybe somethng Better is not too much more ..... hopefully ... :thinking:
Postby CharlieL » Tue Jan 12, 2016 9:39 pm
did Y'all forget about "THE MIX"? Treat the floor plywood with it as well. should be good for go then.
Someday I will get off my rump and jump into a build, Thanks folks, for the info. and the things y'all do for one another
Charlie
CharlieL
Postby GPW » Wed Jan 13, 2016 7:57 am
CL, True , but some people ignore the floor .. thinking the ply alone will survive ... :roll:
But then again , it’s the nature of wood t take in water ...all those little tubes .... capillary action , working against us ... Actually OSB is better as a wood product, because the tubes only run so far , not full length of the product ... Still looking for a better floor materiaL , one impervious to water ... :thinking:
Postby alaska teardrop » Thu Jan 14, 2016 11:35 am
Lightweight.
No wood rot.
Insulated floor.
Not foamies, but two examples of the sketch above.
.063" aluminum riveted to frame, 2" extruded polystyrene, lay flat/no glue vinyl flooring.
.050" aluminum riveted to frame, 1-1/2" extruded polystyrene, 1/4" oak plywood flooring.
Fred
alaska teardrop
Postby GPW » Thu Jan 14, 2016 4:16 pm
FRED, Nice Job !!! :thumbsup: 8) :applause:
