hankaye wrote:Stormcrow, Howdy;
Is that your Safety Officer in the last photo? I'd follow any recommendations.
hank
wanabxtrm wrote:Glad to hear post repairs it rode well. I'm curious how you aligned the axles when you did the spring over conversion. I assume the spring mount location wouldn't change and all you need to align is the axle perch directly over the existing lower perch, ensuring its perpendicular to the axle?
Any other lessons learned on it?
Thanks,
Ol' D wrote:Stormcrow,
Hi , I like your trailer, it has nice possibilities . With the receptacles you could bring in a power entry above or below the receptacles and run power to the inside receptacle and daisy chain the outer one from the inside giving you a power outlet inside and out. I would suggest that you change out the first receptacle with a GFCI one.
Good to see another Tim "The Tool Man" Taylor join the crew. Always interesting to
watch as they fabulate something wondermus.
hank
Iconfabul8 wrote:Nice work, it is always nice to see someone else doing the steel fab thing!
Users browsing this forum: W3C [Validator] and 14 guests
