The plan:
Independent suspension trailer base running on 35" tires (to match the tow rig)
Will carry our engel 45 fridge
Will have a small AC unit on board
Two doors from Vintage
Anodized aluminum skinned in .040 (possibly .063 on the roof)
4.5' wide, 4' tall, ~110" long
Day 1, trailer arrived. Some assembly required. 3 sticks of 2x2 .120 and one of 2x2 .250
Lots of chopping
Not bad for the first day, frame is laid out. Tongue needs some work.
De-burred the seam in the .250 wall tube so I can get the spindles to fit.
Used a rotabroach to drill holes for the plug welds. Amazed by these cutters, almost makes drilling enjoyable.
Had to heat the .250 wall tube and freeze the spindles over night to make them fit.
First side slid in perfectly, second side I had to hit with an air hammer to full seat. As is they are not going anywhere.
Building the arms was not fun. To save money I used the 2x2 .120 material that I already had on hand. If I could do it again I would use 1.75" or heavy wall 1.5". But this will do. Using YJ bushings with DOM sleeves that I purchased from WFO concepts.
Squaring everything was a PITA, learned how un-level and sloped my garage floor was. Got everything in to about 1/16 of being square, but after welding that turned into 1/8. Not happy but should be fine.
Began getting the arms aligned onto the axle. I will cut the center out of the axle after its aligned to the frame and the brackets are fully welded.
And a preview of the air bags and retainers that will be using.
Axle alignment was not fun, took two days, some cursing, a laser level and some more cursing. Main issue was dealing with the weight and angle of the axle with the arms welded to them. Ended up adding some cheat plates to the frame which made it a breeze to setup and prevented it from wandering.
Cut the center out and now I have two arms. Had to add another cross member to support the top of the air bags. Once it was tacked in place things started to look pretty good.
Found some brake backing plate mounts on ebay for square tube. They were cheap enough and the seller sent them super fast so that saved me some time and I avoided setting up the plasma for another week.
Kinda completed the tongue, did a square notch for the first time and I am not sure I like it. But this leaves me room for the junction box for the electrical at least. Also using a receiver hitch at the tongue so I can switch from a standard coupler to a 3 axis one later.
On the left we have more travel but a less effective shock (7" of travel) On the right we have less travel but a more effective shock (4" of travel). Im went with the mount setup on the left and regret it already, will be re-doing that in a few weeks.
