Shadow Catcher wrote:Conservation is the other half of the equation, LED lights not using anything with resistance heat, i.e. coffee maker... Most chargeable electronics can be powered with 12V, anything using a USB, laptop, Cell.
I have a 185W high voltage panel feeding through a Morningstar Sunsaver MPPT controller into a 150AH AGM batter, but we are powering among other things a WAECO 12V refrigerator.
Esteban wrote:I bought a Grape Solar 160 watt panel that will be mounted on the roof of my teardrop. It was purchased from Amazon.com for $229.99. Home Depot sells it online (not in stores) too. The solar panel will be mounted to the roof with Instapark Drill-free Solar Panel Mounts which get permanently glued to the roof and add a little bit of an aerodynamic look.
My teardrop will be 64" wide on the outside to accommodate the 58" x 26" solar panel and the solar panel mounts on the roof. That width also provides room inside the cabin for a queen sized mattress.
One of my motivations to have a relatively high wattage solar panel is to provide sufficient battery power so I can use an ac/dc fridge freezer like the TruckFridge TF41 or an ARB 37 Fridge Freezer. Won't need to buy ice every couple of days. No soggy food. Cold adult beverages. Ive cream. Off-the-grid boondocking.
lrrowe wrote:Esteban wrote:I bought a Grape Solar 160 watt panel that will be mounted on the roof of my teardrop. It was purchased from Amazon.com for $229.99. Home Depot sells it online (not in stores) too. The solar panel will be mounted to the roof with Instapark Drill-free Solar Panel Mounts which get permanently glued to the roof and add a little bit of an aerodynamic look.
Did you see my post where I noticed that they say they have new models coming this summer?
http://tnttt.com/viewtopic.php?f=2&t=65086
I know this is an expensive consideration, but because of these possibly better units this summer, I might consider getting a very small dorm refrig to hold me over til then or to get the smallest Truckfridge model now and also consider the larger TF51 (new model) this summer to go along with it. My logic is that this small model can be a portable that I use with the CT or with my TV when I travel w/o the trailer attached. Heck money is no object, right. Well not really and this may only be a dream.
Return to Essential Information about building teardrops
