Tyvek skin on foam?
Tyvek skin on foam?
Postby Don L. » Thu Jan 07, 2016 6:26 pm
Hi,
My first post here and I have very much appreciated everyone's stories and advice. I have been reading a lot the past couple of weeks. In fact it is because of everone's shared experiences building with foam that I have just bought a trailer frame to begin my first build.
I did a quick search to see if anyone has used tyvek as a skin on foam and didn't see anything so I just wanted to ask "has anyone had any experience with it"?
I have just glued a small sample of tyvek to foam using regular carpenters glue to see if it holds. I have heard of tyvek being glued in other applications but I have no direct experience of that.
I'll post my results when it dries. I guess I should also do a paint and primer test!
I had posted this in the Tips and Techniques section but since I am doing a foamie I wanted to be sure all you foams saw it.
Best,
Don
Link to my foamie camper build viewtopic.php?f=55&t=67321
instagram #don_leister_violin.rva
Don L.
Re: Tyvek skin on foam?
Postby tony.latham » Fri Jan 08, 2016 12:21 am
Here's what my search came up with...
viewtopic.php?f=55&t=65094
T
Postby Don L. » Fri Jan 08, 2016 7:10 am
HI Tony, I can't seem to get the link to do anything.
Don L.
Postby lrrowe » Fri Jan 08, 2016 7:12 am
It comes right back to this post.
Bob
lrrowe
Images: 439
Postby GPW » Fri Jan 08, 2016 7:46 am
Perhaps we need to run this past the Foam flyers on RCGroups.com .... They’ve tried most everything ... I’ll be back ...
Postby KCStudly » Fri Jan 08, 2016 9:34 am
I seem to recall the issue being that Tyvek is a moisture barrier so water based glues (and probably others) don't stick to it well.
Postby tony.latham » Fri Jan 08, 2016 11:55 am
lrrowe wrote:It comes right back to this post.
Sheeeesh, it came back that way to me too, so I thought I'd deleted it.
Anyway, if you dump tyvek into the google search box on this forum, you'll get many-many returns. Here's the link using an Advanced Google search: https://www.google.com/search?as_q=tyve ... as_rights=
I hope this helps! :thumbsup:
Postby Don L. » Fri Jan 08, 2016 12:25 pm
Yes, that helps a lot! Thanks Tony.
I tried the advanced search with no luck but the custom search got some results, so now I know.
Well, the tyvek sample stuck pretty well to the foam board. When I peeled it away sometimes the tyvek delaminated and sometimes a thin layer of foam would come off and sometimes the glue stayed put and the tyvek let go. It was a large tyvek postal envelope. The carpenters glue grabbed it quickly and it stayed in place so I think I am going to try painting it with some gripper primer.
Don L.
Postby GPW » Fri Jan 08, 2016 1:28 pm
Maybe the gripper might hold it ....primer and all ... ??? :thinking:
Postby Don L. » Sat Jan 09, 2016 8:56 am
I will have to get some gripper and try a sample to see how it grabs and lays down. My main reason for considering tyvek is to get a smooth surface and ease of handling. But I suppose the final surface will be paint and how that is put down. Probably with a roller, so that should look pretty decent, maybe gloss paint which would leave some texture.
I'm thinking out loud here so anyone's comments are welcome.
I have read a fair amount about paints that folks use and I gather that exterior latex house paint is pretty good?
Don L.
Postby KCStudly » Sat Jan 09, 2016 10:21 am
Tyvek doesn't form and mold around compound surfaces the same way woven cloth does.
Postby Talia62 » Sat Jan 09, 2016 10:32 am
KCStudly wrote:Tyvek doesn't form and mold around compound surfaces the same way woven cloth does.
Wellll...not when it's new off the roll, no. Let me elaborate...
Tyvek is widely used in the ultralight backpacking community as a moisture resistant, lightweight ground cloth or tarp material. But, when we're sleeping on it or under it in the wind, it's noisy and stiff. So many of us will soften it by throwing it in the washing machine for two or three cycles on cold or warm, with a pair of old shoes in with it to beat it up some. NO DETERGENT, just water. Some people will scrunch it up by hand, first. Then after you wash it two or three times, take it out, hang it up, or lay it out on the grass and let it dry.
It ends up with about the body of cotton fabric, and I suspect it would be much more inclined to form to a trailer body once it has been prepared this way.
Talia62
Postby GPW » Sat Jan 09, 2016 11:08 am
T62,Thanks for that !!! :thumbsup: 8) ...
Here’s what the RC boys had to say ... http://www.rcgroups.com/forums/showthread.php?t=2577240
Postby Talia62 » Sat Jan 09, 2016 11:17 am
GPW wrote:T62,Thanks for that !!! :thumbsup: 8) ...
Interesting how so many different hobbies (trailer building, camping, backpacking, RC planes) have so many areas of cross-over.
Talia62
Postby wagondude » Sat Jan 09, 2016 2:43 pm
I know they use adhesive on the flap of the envelopes, but what do they use on the seams? Is it an adhesive or are they heat welded? If we knew how that was done, we might find the answer to the whole question.
Some food for thought: https://en.wikipedia.org/wiki/Tyvek
Bill
101137
wagondude
Images: 35
