Post your Foamies here ...
Postby tac422 » Tue Jan 12, 2016 6:33 pm
Please post a picture and a little info about your foamie build here.....
name: The Big Pink
HF4X8 trailer, weight 900 lbs, 10' x 6'
Canvas over 2" foam, Queen size bed, ac, fridge, dropped floor standie
123716
Build started here: http://tnttt.com/viewtopic.php?f=55&t=44091
and finished here: viewtopic.php?f=55&t=56441
tac422
Re: Post your Foamies here ...
Postby GPW » Tue Jan 12, 2016 6:45 pm
NICE One Tac !!! :thumbsup: 8)
Postby KCStudly » Tue Jan 12, 2016 7:38 pm
Name: The Poet Creek Express
Status: Work in progress
Profile: Custom Benroy meets canned ham-esque (Benroy front, arched roof, “bustle” shaped hatch).
Trailer: 64 wide x 9ft 8in long 2x2 steel square tube home built; off road capable w/ Jeep suspension, shocks, bump stops, over rated large brake big bearing axle, and custom made swivel hitch. 31 inch AT tires on 15x10 Teflon coated aluminum wheels.
Hybrid construction: 5mm marine Okoume ply cedar framed sandwich floor and bulkhead; 5mm Okoume interior skin and cabinet shelves; 1-1/2 inch XPS foam walls, roof and floor; fiberglass reinforced epoxy outer skin. Homemade doors w/ flush mount windows.
Weight: TBD, target 1200 lbs all up.
Electrical System: 12v DC w/ on-board smart charger and portable solar; all LED lighting; dual linear hatch actuators; custom switch plates w/ maple trim; Maxxair Deluxe roof vent and 5 inch case positive pressure vent.
Postby KennethW » Tue Jan 12, 2016 8:34 pm
This is my 5 wide by 9 long no wood foamie. On a harbor freight trailer. The curved roof makes the roof stronger. Well almost no wood. The floor in the galley and the galley wall is wood.
132999
It has FRP on the inside of the 1" foam ceiling with canvas glue on the roof. The side wall have canvas on the inside of the 1" foam and FRP on the out side The floor is FRP on the inside 2" foam and canvas underneath.
138450
It has Wylie windows and bars that pull out for changing.
138449
A drop floor in the galley and a bin under the bed.(It was a mess after 2 weeks on the road and has been redone).
133190
I changed the tongue for a center jack with pipe spacers. I also lowered the trailer with the axle over the spring and removed the center leaf for a softer ride.
138447
Ready to go. untested from MN on a loop of 6 NP's in two weeks. Six days before this picture there was no floor in the galley and was unwired.
138446
With the giants. I think that is the parking lot at dinosaur NP
138448
Rocky Mountain NP
138445
My dog and the Wilie window fully vented dog dish propane radiant heater.
KennethW
Images: 82
Postby GPW » Wed Jan 13, 2016 8:44 am
Foamie #1 ... About as simple as it can get ... Held up Super through all kinds of weather .... Bonnie owns it now ... :thumbsup:
A1F fin .jpg (149.26 KiB) Viewed 1614 times
Postby eaglesdare » Wed Jan 13, 2016 9:22 am
I forgot how to post pics! :lol: :wine:
Louella
May the foam be with you.
eaglesdare
Postby kudzu » Wed Jan 13, 2016 2:43 pm
KennethW wrote:138446
Like our earliest mammal ancestors dwarfed by the dinosaurs who were unaware of their impending extinction.
kudzu
Images: 16
Postby GPW » Wed Jan 13, 2016 6:35 pm
Eagle ... :roll:
K', Dinosaurs no one can afford the maintenance on anymore ... Likely caused by the trailer manufacturers making their units so they only last through the warranty period , then systematically fall apart ... Vulture Capitalism strikes again ... :R
Postby KennethW » Wed Jan 13, 2016 6:57 pm
GPW wrote:Eagle ... :roll:
Motorhome are really bad as far as maintenance. One does not wear out tire they age out along with everything on a motorhome. With a TD replacing the drive train is replacing your dally driver. :thumbsup:
I can most likely build a new foamie for the cost of two of their payments. And at 640 # I can go anywhere without fearing the gas pump.
KennethW
Images: 82
Postby pchast » Wed Jan 13, 2016 9:47 pm
4X8 HF trailer. 1.5" foam no galley. 560lb
pchast
Images: 97
