joining four walls
joining four walls
Postby mariannf » Wed Jan 20, 2016 12:02 pm
Hello TNTTers,
I have a build started, it is a 5x10x5 Rimple, no galley: http://tnttt.com/viewtopic.php?f=50&t=64888
Question for anyone with experience: I am planning on having rear and front ply walls. If you go to the link to my build you will see the top curves of the side walls have a 19" radius. So I want to have a front and rear walls of 3/4 inch ply (same as sidewalls) that goes up 41 inches. I have been searching the site, but can't find advice/examples on how best to join the sidewalls to the rear and front walls.
Any help appreciated!
Mariann
mariannf
Re: joining four walls
Postby S. Heisley » Wed Jan 20, 2016 9:06 pm
Hi, Mariann: Since I'm following your build thread, I put my example there.
Postby steve cowan » Wed Jan 20, 2016 9:32 pm
Hi,
Probably the best way is to rout a channel,but not the easiest.I used 3/4 inch C channel aluminum attached to the outside wall with small screws and adhesive.
Then i slid the "bulkhead " in place and used small screws to secure to the C channel.
101486
101492
In the pic you can see the C channel [painted brown].
steve cowan
Images: 207
Postby noseoil » Wed Jan 20, 2016 10:32 pm
3/4" wide X 1/4" deep rabbet joint in the side walls.
137905
noseoil
Images: 670
Postby dales133 » Wed Jan 20, 2016 11:08 pm
noseoil wrote:3/4" wide X 1/4" deep rabbet joint in the side walls.
Yep,thats what id do
dales133
Postby mariannf » Thu Jan 21, 2016 11:56 am
steve cowan wrote:Hi,
Hi there Steve and thanks!
This sounds like a great idea, but you said it wasn't the easiest method. my woodworking skills aren't great so this method is appealing why do you say it wasn't easy?
Many thanks!
mariannf
Postby steve cowan » Thu Jan 21, 2016 6:46 pm
Mariann,
Sorry I wasn't clear in the post.What I meant is a rabbet joint would be best but not easiest.Since I wasn't sure where the bulkhead was going until the outside walls were in place I used the C channel .Good luck!
steve cowan
Images: 207
Postby mariannf » Thu Jan 21, 2016 10:53 pm
steve cowan wrote:Mariann,
Thanks Steve! I have gotten some advice on my build thread and will go with a wood cleat at the joint and appreciate your thoughts on this.
mariannf
Users browsing this forum: Bing [Bot] and 5 guests
