New unnamed 5x8 teardrop build
Postby SPLAT » Mon Jan 25, 2016 1:55 am
Sold off our Coleman Cheyenne and downsized... We purchased a 5x8 kit last year and after much procrastination I have started the process of building it :thumbsup:
Picking up our kit and driving home
The frame
Dexter axel
Joe~
SPLAT
Images: 23
Re: New unnamed 5x8 teardrop build
Postby SPLAT » Mon Jan 25, 2016 2:02 am
I had the kit for a month or two before I got motivated to start the build...
Placed all trailer light wiring in conduit and used water proof splice connectors.
Originally tried to use a glue on mesh fabric for a vapor barrier, discovered it was NOT water proof... Removed!
Painted bottom with a Henry's roof seal product and then flipped it over to be attached to frame
Joe~
SPLAT
Images: 23
Postby SPLAT » Mon Jan 25, 2016 2:11 am
The original vapor barrier was intended to wrap up the edges of the siding under the aluminum... I Used a water proof flashing tape. I placed the tape on the frame with the sticky side up and laid the floor down on it allowing 3 inches of the tape to extend past the plywood. Before I attach the aluminum siding I will wrap the tape up and seal the joint where the floor and side walls connect. :twisted:
Screwing the floor to the trailer frame. I left the peel off backing attached to the exposed flashing tape to keep it clean and free of debris until I am ready to stick it to the side walls
A little adhesive for the linoleum
Smoothing out the linoleum
Joe~
SPLAT
Images: 23
Postby SPLAT » Mon Jan 25, 2016 2:17 am
Now to trim the aluminum sheeting to match the side walls and door cut outs... Then Install the walls :thumbsup:
Sawhorses, clamps and a router... Perfect fitting aluminum
Glued and screwed one sidewall on...
Then the other wall, with the crossmember spars glued and screwed in place
Joe~
SPLAT
Images: 23
Postby SPLAT » Mon Jan 25, 2016 2:30 am
Treating the interior ceiling wood with two coats of varathane... 2 peaces x 2 coats per side x 2 hour dry time between coats = a LONG day :SH
But it had to be done and looks really nice now.
Watching paint dry...
Attaching the ceiling...It should have been a simple task, but it was difficult to get the two sheets aligned. There may or maynot have been some minor profanity, a dozen clamps, 2 trips to the hardware store and lots of help from the wife :)
Now we are ready to assemble the cabinets. Glad I did a test fit, a few of the panels were a little to wide.
Joe~
SPLAT
Images: 23
Postby KCStudly » Mon Jan 25, 2016 4:24 pm
You're off to a good start! :thumbsup:
Who did you buy the kit from?
Postby Woodbutcher » Mon Jan 25, 2016 6:49 pm
Lookin good. Keep going, making sawdust gets you to the end.
Woodbutcher
Postby SPLAT » Mon Jan 25, 2016 11:33 pm
KCStudly wrote:You're off to a good start! :thumbsup:
DNR Teardrop Trailers
Joe~
SPLAT
Images: 23
Postby Hoosier Daddy » Fri Feb 05, 2016 4:16 pm
I have gone to find myself.
If I should return before I get back, please ask me to wait.
Me
Hoosier Daddy
Postby SPLAT » Thu Feb 11, 2016 7:54 pm
Hoosier Daddy wrote:Do you mean DNM TeardropTrailers?
http://www.dnmteardroptrailers.com/oregon-trailer-kits/
YES!
Haha...
Joe~
SPLAT
Images: 23
Postby SPLAT » Thu Feb 11, 2016 8:06 pm
Well, things have been stop and go for me but I finished the trimming the interior, finished the electrical and installed some lighting...
Today I insulated the roof and installed the 1/8th inch vinyl sheet that goes down before the aluminum. I used packing tape to hold the insulation in place while I worked, since it was windy.
Used tie down straps to position it and hold it in place...
Then I used 1/4" x 3/4" staples to get it on smooth and tight... I was a little worried but managed to get it on perfect :worship:
Stapled in place
Maybe tomorrow I will tackle the diamond plate and aluminum roof sheet... The aluminum worries me, I want it to look professional and it won't take much to make a mess
Joe~
SPLAT
Images: 23
Postby SPLAT » Fri Feb 12, 2016 1:39 am
Test fitting the hatch to make sure the curves match :thinking:
Hatch fit check
Pretty close to perfect :thumbsup:
Joe~
SPLAT
Images: 23
Postby SPLAT » Fri Feb 12, 2016 1:40 am
Got the door installation figured out!
Joe~
SPLAT
Images: 23
Postby noseoil » Fri Feb 12, 2016 7:43 am
Looks really nice! :thumbsup:
137905
noseoil
Images: 670
Postby jkidd6339 » Fri Feb 12, 2016 9:29 am
Looks nice. What size router bit and how fast was it turning to trim the aluminum?
jkidd6339
