First build 5x10 Rimple design
Re: First build 5x10 Rimple design
Postby mariannf » Sat Jan 23, 2016 5:46 pm
Hi all, I gave the new router a spin and understand why it is recommended. After using the jigsaw it is like driving a Cadillac. That said I have a question: for purposes of making the rabbet for the side all and bulkhead wall a few have suggested that the rabbet be 1/4 x 3/4. I understand that to mean I cut into the 3/4 ply at a depth of 1/4, and then cut a chanel that accommodates the 3/4 ply bulkhead wall. Is this right? Please see the hand drawn pic I posted in an above post.
If this is right I don't understand how to get to the 3/4? The standard rabbet router bit makes the Chanel 1/2 at most.
Thanks!
mariannf
Postby KCStudly » Sat Jan 23, 2016 6:09 pm
That's right. You should clamp a straight edge for the edge of the router shoe to guide on. You want to measure from the edge of the cutter to the edge of the shoe (or base) on your router and space the straight edge that same distance away from where you want the edge of the cut to be; it is better to err on the short side and have to mach an adjustment than it is to miss wide.
For a rabbet you can set the guide up once, free hand a couple of passes near the edge of the ply (it is better to make a few shallower passes than it is to try and hog the whole thing out in one pass) and then use the guide for the clean edge cut.
For a dado in the middle of a sheet you can either set up two straight edges like an alley and just clean out every thing between them; or you can set one and make the necessary passes down one side of the dado, then set the guide on the other side and clean out the rest. Using two straight edges makes it easier because you can do both sides and only have to change the depth settings on the router once for each pass.
There may also be situations where you want to scarf an area wider than the offset of the router shoe. In those cases it is better to work from the middle of the cut outward, otherwise you might not leave anything to support the shoe. With just one side of the shoe supported the router can get a little tippy (unless you use perfect technique) so I like to attach a shim the same thickness as the cut depth... I call it an "outrigger"... which helps support the router better. For simple short passes it's less of an issue, but when going around shapes and such when your hands have to cross over it is easier hold things stable and takes less concentration.
Postby mariannf » Sat Jan 23, 2016 8:31 pm
KCStudly wrote:That's right. You should clamp a straight edge for the edge of the router shoe to guide on. You want to measure from the edge of the cutter to the edge of the shoe (or base) on your router and space the straight edge that same distance away from where you want the edge of the cut to be; it is better to err on the short side and have to mach an adjustment than it is to miss wide.
Thanks KC! What type of bit should I use? I have two rabbet ting bits, but the max width of the cut is about 1/2. That is the distance between the ball bearing and the blade. If I set up a straight edge, I still need a bit that can make a 3/4 inch Chanel right?
mariannf
Postby KCStudly » Sat Jan 23, 2016 9:44 pm
For what you are doing I would use a straight cutting bit with no bearing and work flat cutting with the end of the bit, not the edge.
This video shows what I mean. With a 1/2 inch straight cutting bit you will need to make multiple passes.
This guy is entertaining to watch and is prolific at making woodworking videos; in this video he discusses router basics.
Postby mariannf » Sat Jan 23, 2016 10:34 pm
KCStudly wrote:For what you are doing I would use a straight cutting bit with no bearing and work flat cutting with the end of the bit, not the edge.
Yes those videos and others helped.
Last question for now if you wouldn't mind. What do you mean by flat cutting with the end of the bit? Once the bit goes down into the wood it looks like it is the edge doing the cutting as you guide it forward. Is there another technique?
Got it about making a fence and then doing a couple of passes to get to the 3/4s.
mariannf
Postby KCStudly » Sat Jan 23, 2016 11:11 pm
mariannf wrote:What do you mean by flat cutting with the end of the bit? Once the bit goes down into the wood it looks like it is the edge doing the cutting as you guide it forward.
Well, yes, of course you are correct, sort of. The cutters cut on their diameters as well as their ends. I was trying to describe the difference between using a rabbeting bit, which to my mind cuts from its diameter in a swath, rather than a straight cutting bit, which to my mind mills like an end mill. But of course the straight bit still cuts on its diameter as well.
My point being that in order to make the desired cut with a rabbeting bit, the cutter diameter would have to be twice the width of the cut plus the bearing diameter {(3/4 x 2) + 1/2 = 2 inches). That's a huge bit that would need a big profile router and would not typically be something you would want to handle in a hand held operation.
Postby mariannf » Sat Jan 23, 2016 11:26 pm
Ok got it thanks KC! I'll take some practice runs!
mariannf
Postby mariannf » Mon Jan 25, 2016 3:09 pm
curved framing 2.jpg (30.79 KiB) Viewed 3327 times
curved framing.jpg (36.44 KiB) Viewed 3327 times
I started cutting the curved framing that will go on the sidewalls. I used spare 1x12, laid it under the wall and traced the wall curve. Then I cut using a jigsaw which I found much easier than a router for this work. the finished framing is about 1x2...which is what i am using through out for framing. I will glue it and screw it on when closer to installation, and then sand it to smooth out imperfections.
mariannf
Postby KCStudly » Mon Jan 25, 2016 3:48 pm
A couple of pointers; it would be better to use narrower stock... say 1x4... and miter cut them around the curve as you go. You will get less waste that way and the grain will follow around the curve (perpendicular to the radii) more consistently. With the 1x12 you will waste more wood and the grain has transitioned to end grain by the time you got around the curve. It is much more likely to split and won't take a screw as well.
On the jigsaw vs. router; cut the blanks with the jigsaw but go wide of your line by about 1/8 inch. Then after you fasten it to the side, run the router with a top bearing flush cutting bit with the bearing following your nicely sanded wall edge trimming off the excess. That way the blocking will match the wall perfectly, best of both worlds.
Postby mariannf » Mon Jan 25, 2016 4:36 pm
KCStudly wrote:A couple of pointers; it would be better to use narrower stock... say 1x4... and miter cut them around the curve as you go. You will get less waste that way and the grain will follow around the curve (perpendicular to the radii) more consistently. With the 1x12 you will waste more wood and the grain has transitioned to end grain by the time you got around the curve. It is much more likely to split and won't take a screw as well.
Thank you KC!
mariannf
Postby mariannf » Mon Jan 25, 2016 5:36 pm
Hi all,
I have a framing question:
I am planning a cabin light, and I am not sure what is required/suggested for mounting it. can it be secured right to a cross spar? does additional framing need to be built in to the ceiling?
Many thanks!
mariannf
Postby dales133 » Mon Jan 25, 2016 6:20 pm
Just screw it into the spar
And as KC said in his last response,thats exactly how i did my frames and it worked out easy
dales133
Postby S. Heisley » Mon Jan 25, 2016 7:26 pm
mariannf wrote:Hi all,
Many thanks!
Yes. Remember that you will probably have to make a path in the spar for the wires. You don't need much. You can probably drill a hole to run the wires through or route a path with that new router you've got.
Only if you don't already have a spar there.
Postby mariannf » Mon Jan 25, 2016 8:43 pm
Thanks Dale and Sharon!
mariannf
Postby mariannf » Sun Feb 07, 2016 3:26 pm
The attachment image.jpg is no longer available
After a hiatus, I have started making the cuts for the doors and windows. I marked their location based on the drawn plan, then based on advice in the forum and examination of the pieces traced them out using the trim ring. All pieces were bought from vintage technologies. I made the cut for the first window using a jigsaw. I cut about 1/8 of an inch inside tje trace mark to assure I didn't make the cut too big. The initial cut was a bit too small so in a very slow process of making adjustments with both the jigsaw and sander I got the first window cut out. There is one more window and two doors.
mariannf
Users browsing this forum: jdeleon and 5 guests
