A (sort of) foamie project I am considering
Re: A (sort of) foamie project I am considering
Postby Thelgord » Mon Jan 25, 2016 8:50 pm
1) Gorilla Glue (messy but cheap) foam to foam during the build
2) Coat everything in TBII, NOT thinned
3) Cover with Canvas while TBII is still wet
4) More TBII, thinned, until fabric is soaked through
5) Primer and paint
Correct?
Thelgord
Postby Mary C » Tue Jan 26, 2016 3:16 am
Ok, now I am going to tell the way I did mine It was hot when I glued on my canvas so i used a 50 /50 mixture just so th canvas was wet and I could get th canvas on. Once or twice I had to add a little more glue. Some places I put the glue on the foam and on the canvas The temperature and how fast I could work with the glue and smooth out the pieces of canvas dictated how much i used. I used a 3by5 plastic the bakerys use to spread icing, wipe down bowls. When the canvas was dried on the foam, I used Glidden gripper. This paint is very thick. I found that my prettiest, smoothest areas were the areas where I put on a very thick coat without trying for coverage that we are used to doing with regular latex paint. You want it thick and heavy really work it into the fibers and letting it rest on top to dry. I used a palm sandeer and put on another coat of gripper. I then used a good exterior Latex, I am very satisified.
Mary C.
Mary C
Images: 473
Postby Thelgord » Tue Jan 26, 2016 7:37 am
Thelgord
Postby rowerwet » Tue Jan 26, 2016 7:43 am
LIke everything with foamies, we each have a way that works, climate will have an effect on some details
rowerwet
Images: 521
