Mary C wrote:Maybe I don't get it but havent we been through alot of different fabrics, Glues and paints ? Either im guessing here but a lot of people are not reading the thrifty thread because if they were the questions about glues and other materials were answered. not only that but the reasons for each has been covered. Like part of the reason we used Glidden Gripper was beause it filled in the open squares in the canvas providing a smoother finish. I know I tried a third coat of it in some areas and it really did a nice job. The main idea of this was to build a camper cheaply, using all the things we could to build making the build thrifty. I bought a cheap aluminum hinge well it is falling apart litertly, the little bar going down the middle of the hinge is rusting on the ends and has come apart. I have to replace it. That is what made the Thrifty thread so important we have discussed these things and others as they have come up Through expierence and trial an error. So you all can go out an try your plastic fabric and you can get all crazy with your different glues and paints. We have been doing this for four years and we kinda know the things that work. Builders have built here but some have not stuck around or revisited to give us updates on the different things they have used. Most of us that are still here give periodic updates on our campers and how they are holding up in the weather and since they live in different climates we are getting the detailed info on what really works and holds up. I am currently doing an expierment with a product called Big Strech. I t is a type of silicone rubber, water resiistant and can be used with a painted ssurface and a wood surface I know that it works but my question is how will it hold up? Look for my report towards the end of the summer at least I will know how it holds up outside in the weather. First understand the premis, a foam that melts with some glues, a fabrick that will asorbe the glue and glue to the foam. A paint that will smooth out the material and a finish paint that will be cleanable and hold up in all kinds of weather. And build this without spending a lot, it be light weight and use products easily found, scrounged, and known.
My 2 cents
Mary C.
Mary C wrote: (clipped for brevity) First understand the premis, a foam that melts with some glues, a fabrick that will asorbe the glue and glue to the foam. A paint that will smooth out the material and a finish paint that will be cleanable and hold up in all kinds of weather. And build this without spending a lot, it be light weight and use products easily found, scrounged, and known.
My 2 cents
Mary C.
Socal Tom wrote:Maybe I'm doing something wrong, but I tried to read the thrifty thread. over 400 pages, but I see someone made an index. But the pages listed on the index didn't have what the index said?
