Benroy on a utility trailer
Postby fourbtgait » Sun Jan 24, 2016 9:24 pm
Removable Benroy
Trailer, 5x10 utility trailer, 3500 lb axle, removable sides, tailgate. 15" wheels, stakeside. 745 lbs empty.
5x4'2x10'6" Benroy box. 71" +/- ground to roof top. Plus fantastic fan height. Tow vehicle is 72" +/- high.
Pl glue. (Yuck)
Floor weight-136 lbs. 1/4" bb, 1x frame, 3/4" pink insulation.
Each side weight-64 lbs. 3/4" df 3/4 ac ply, skeletonized, 3/4" pink foam, 1/4 birch bead board inside, 1/4" bb outer.
Rear cabinet weight-84 lbs. 3/4" birch ply, biscuits.
Roof weight-88 lbs. 1/8" bb inner, 1x2 spars, 1/8" and 1/4" outer, foil bead board foam.
Rear hatch weight- 68 lbs.
Both doors- 50 lbs.
76 pounds in 6 oz fiberglass, epoxy, outer skin tieing sides/top into one unit.
Approximate box weight is 631 pounds empty.
Rustoleum exterior paint, plain satin varithane inside.
Bought doors, 30"x36". Yes, oversized. :)
Test photo was resized, lets see if its right....
fourbtgait
Images: 16
Re: Benroy on a utility trailer
Postby fourbtgait » Sun Jan 24, 2016 9:25 pm
Hmmmm, to me the photo is to big.
So much for Ipad apps?
Added pictures in photo album.
fourbtgait
Images: 16
Postby fourbtgait » Tue Jan 26, 2016 12:44 am
Basic trailer
fourbtgait
Images: 16
Postby fourbtgait » Tue Jan 26, 2016 12:45 am
Various pictures
fourbtgait
Images: 16
Postby noseoil » Tue Jan 26, 2016 7:53 am
Looks nice, I like the frame, plenty stout. Also looks like it might tip the scales at about 1500# when finished, depending on the "extra" stuff (battery, etc .). Keep posting progress pictures!
137905
noseoil
Images: 670
Postby fourbtgait » Tue Jan 26, 2016 9:45 am
Yes, 1500 but life is a compromise. Also with the frame it sits higher, bed of trailer itself is 22" off the ground. I did not want a dedicated camp trailer, the box will come off by lifting it 3" placinf 3" pvc pipe under and eoll it off.
I have kept track of weights more out of curiosity as in reading thru the site others often asked how much this or that weighed. There is no 110 volt, no ac, no built in stove/sink, etc. it is built for long weekends into the mountains on single track roads pulled by a 4runner. No, not for rock crawling either.
fourbtgait
Images: 16
Postby fourbtgait » Tue Jan 26, 2016 11:04 pm
Seems to take forever to build and ours is not intricate. Life intrudes. Started last mid October, had hoped to be farther along. But marriage, weight training and cardio get in the way. Plus a regular job.
But tonight installed the roof fan and box flooring.
It is 10' overall simply so the lab has the front floor to sleep on, no dogs in a bed.
Sides are a close match to Toyota magnetic grey. Roof is white.
image.tiff
image.tiff (156.22 KiB) Viewed 3129 times
image.tiff
image.tiff (181.65 KiB) Viewed 3129 times
fourbtgait
Images: 16
Postby fourbtgait » Tue Jan 26, 2016 11:07 pm
Simple 12 volt wireing, nothing special. But I do think the 100 amp deep cycle battery is to big.
When I bought the overhead lights and usb ports, I did not realize they draw phantom power. But all are nano amps which together draw way under 1/2 amp hour.
There is no radio, just lights, usb ports and a 12 volt plug in.
Iphones for music, no radio or cell reception where we go.
image.tiff
image.tiff (172.25 KiB) Viewed 3128 times
image.tiff
image.tiff (180.22 KiB) Viewed 3128 times
fourbtgait
Images: 16
Postby fourbtgait » Thu Jan 28, 2016 10:54 am
Box finally set down.
Hour of work, 2 jacks, blocking, wide eyed wife. Sits 1/4" to far forward.
fourbtgait
Images: 16
Postby fourbtgait » Sun Jan 31, 2016 5:44 pm
Nothing yesterday, movement today.
Off to yoga now.
image.tiff
Inside of hold down.
image.tiff (172.51 KiB) Viewed 3004 times
image.tiff
Currently 4 hold downs each side, plus an angle across front that prevents rear movement.
image.tiff (136.56 KiB) Viewed 3004 times
image.tiff
12 volt lead goes into lockable toolbox where battery is. Can be removed.
image.tiff (135.31 KiB) Viewed 3004 times
fourbtgait
Images: 16
Postby Mushin » Sun Jan 31, 2016 10:34 pm
Good looking build!
Mushin
Postby fourbtgait » Tue Feb 02, 2016 10:56 pm
Fits and spurts. Pity one has to work.
How many people install drip caps?
image.tiff
Debating whether to install the drip caps. But yes, they would be painted black.
image.tiff (168.54 KiB) Viewed 2945 times
image.tiff
My better half thinks its her dog house. She loves the queen mattress.
image.tiff (170.37 KiB) Viewed 2945 times
image.tiff
Doors on finally. My eyesight is going, turned out to be square drive screws.
image.tiff (160.98 KiB) Viewed 2945 times
fourbtgait
Images: 16
Postby KCStudly » Wed Feb 03, 2016 3:29 pm
I don't see the last couple of rounds of pictures, just attachment and title info. :NC
Have you changed how you have been loading pics?
I really would like to follow along. :D
Postby fourbtgait » Wed Feb 03, 2016 3:40 pm
No I have not changed. Must be the site.
I take them with my phone. Email them to myself so they are smaller and attach like normal in a message.
fourbtgait
Images: 16
Postby vincigj » Thu Feb 04, 2016 11:30 am
Nice build. I installed drip caps to keep water out of the door before first seal. Helps a bit. I did have them power coated to match my black door and black porch lamps.
vincigj
