by KCStudly » Wed Jan 27, 2016 6:21 pm
Are you trying to describe a slip joint with gasket or a rigid connection? I would avoid any rigid connection, especially if it is higher up on the TB. It might work out okay, but I wouldn't consider it a good practice.
I am mounting my TB on rubber isolation mounts (it's a long story) so I wanted to make sure there was some flex in the conduit. Our cabins are rigid and trailer frame tongues can flex a little bit, so it is better to have an offset in you conduit that allows for some give and take. By having a 90 deg fitting on the bottom of both units and aiming them at a slight angle to each other (with the flex conduit following a slightly curved path, or even a slight S-shape), the system will be able to absorb any relative motion that is to be expected. Also, any flex at the base of the front wall will translate into more relative motion near the top of the TB further away from the mounting points, so it is best to place the "bridge" close to the relative pivot point.
A straight short rigid connection up between the front wall and back of the TB might "work" on itself always going from tension to compression with no chance to flex; which over time could "bust' (or degrade) whatever seal or fastening method you use.
Even with the flex conduit it is better to have a slight bend or S-shape offset to avoid a straight push or pull scenario.
I know I tend to engineer the heck out of things. I figure if I can make something better just by considering the possible outcomes and using well published techniques that don't really take anymore or less effort than any other, then why not try to incorporate good design practices? In the end it might not matter in your scenario, but it is something to consider.
I'll just add that I have years of routed systems design and industrial maintenance experience. I've seen how even the little insignificant things can cause more than a little failure when done poorly. Not that your craftsmanship is in question... not at all, it's just that you'd be surprised how small details can make the difference between a long trouble free service life or not. Just saying.
KCStudly on Fri Feb 05, 2016 8:45 pm, edited 1 time in total.
My Build:
The Poet Creek Express Hybrid Foamie
TnTTT ORIGINAL 200A LANTERN CLUB = "The 200A Gang"Green Lantern Corpsmen
