KCStudly wrote:Maybe you were traveling in the wrong direction with the router? You want the cutter to be turning so that if it was a wheel it would be driving the router in the opposite direction to the travel direction.
In other words, a conventional cut.
Here, this will explain it better: Lee Valley Link.
KCStudly wrote:Another possibility could be that you were trying to take too much in one pass. If that is the case you can leave your fence where it is and take a free hand pass slightly off the fence (w/o fear of an oops) before taking another pass against the fence.
I find anything more than about 1/3 the cutter diameter is too much; less for harder woods.
Edit to clarify: when using 1/2 inch flush cutting bits.
S. Heisley wrote::thumbsup: Very nice!
