gudmund wrote:almost forgot - I do also carry a bicycle pump, but after having to use it a few years back to air up my space when I had a flat in over 95+ degree weather, I will say it did work - BUT - after well over 200+ pumps of it to get the pressure from 18 lbs to 58 lbs for the compact spare, I do not hope or plan to go threw that again!!! (it was after I was done that I remembered I did have a can of Fix-a-Flat that I had forgot about) Something to remember about bicycle air pumps - they for the most part are for "high" pressure, "low" air volume bicycle tires - where car tires are "low" pressure, "high" air volume tires which takes "a lot" of air to fill up !!!!!!!!
