I have three 12 volt deep cycle batteries that will be connected together and live in a tongue box on my trailer (12 volt system).
The charge controllers (plug-in plus solar) and the rest of my electronics including the 1000 watt inverter live inside the trailer itself. Thus, I will need heavy gauge cables connecting the batteries to the inverter & distribution center inside the trailer.
I am familiar with the need to have the load cables connect to + and - on opposite ends of the battery bank to equalize the electrical draw across all three batteries and maximize their lifespan.
Quick Questions:
1) Do the wires from the battery charger need to connect to the battery bank at opposite ends for the same reason (equalizing the charge), or can they go to the middle battery terminals, for example?
2) Can the charger instead be hooked up to the same load cables as the inverter on the trailer (power distribution) side (to eliminate the need of running separate charging wires into the tongue box)?
I am not familiar with the pros and cons of wiring the charger to the load cables rather than the battery terminals themselves. Would there be an issue when solar charging and running the inverter at the same time, for example?
Thanks for clarifying these issues for me before I set up the tongue box wiring!
Lauren
