by fourbtgait » Sun Mar 20, 2016 9:42 pm
Two weeks busy doing other things.
Sanded, repainted the outside grey today. Thought it might be to light and once hitched to the 4runner, it was. Only takes 30 minutes to unbolt, lift off of trailer.
Lot of little things to finish, door knobs, coat/towel hooks, drip caps, etc.
The bare trailer had a tongue weight of 275 pounds. Bare box on the trailer with matress inside, 60 pound battery in tongue box has a tongue weight of 224 pounds. As set up now, trailer weighs 1450, so 15%. Not bad.
Once set back down, I will load up all gear that will stay in trailer, recheck. I will use the 7 gallon water jug and the ice chest as movable ballast. Need more tongue weight? Put those in front of box when traveling.
- Attachments
- Interior cabinets, just need add knobs.
- image.jpeg (37.55 KiB) Viewed 1241 times
