Kansas City Home Built Teardrop
Postby RustyFenderBrewer » Mon Feb 29, 2016 9:18 pm
I've spent several months lurking here and elsewhere learning about teardrop construction in preparation to building a camper with my brother for him and his wife. I wanted to wait to begin a build thread until I had something and that time is now. I'll be uploading pics to my album and updating this thread as we progress on the build.
RustyFenderBrewer
Images: 62
Re: Kansas City Home Built Teardrop
Postby RustyFenderBrewer » Mon Feb 29, 2016 11:15 pm
So, continuing the story... We bought a boat trailer on January 29th. We had looked at Harbor Freight trailers but rejected them for several reasons: 1) my brother is 6'3" and wanted a queen-size mattress for length resulting in a 5' x 9' trailer floor. 2) we wanted 14" or larger wheels for the look and for additional ground clearance. And 3) price. We got the boat trailer for $200 with new 14" tires and 20-footer chrome wheels. We spent less than $200 for the required steel, paint, etc. to complete the frame.
Here's the trailer:
139734
139735
In a couple hours we had the trailer reduced to two side frame rails with the leaf springs still attached and the trailer tongue.
139736
139737
The section in the picture below that says "Heritage" is what we took out of the frame length. Notice how wide that axle is, too. I fix that the following day.
139738.
RustyFenderBrewer
Images: 62
Postby RustyFenderBrewer » Mon Feb 29, 2016 11:26 pm
I guess I should post up a pic of my brother's fullsize drawing.
139733
The boat trailer was 6' between the fenders and our plans called for only 5'. I cut 12" out of the center of the axle.
139739
I then plug welded a piece of 3/16" angle inside the axle ends. Using clamps and more angle iron to ensure the axle was straight in both directions I welded up the seam and remaining plug welds.
139740
139741
Now we had to mock it up to see if everything was going to fit as desired and to determine the final lengths for both side rails as well as the tongue.
139742
139744
139743
Those wheel look like junk, right? We had a little more time so we scrubbed them up, too. First one...
139745
Then the other...
139746
RustyFenderBrewer
Images: 62
Postby Vedette » Mon Feb 29, 2016 11:27 pm
Welcome to the Forum
Your build looks like an interesting one to follow! :thinking:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby RustyFenderBrewer » Mon Feb 29, 2016 11:39 pm
We cut the side rails and trailer tongue to our desired lengths. I made a metal run for Assorted sizes box tubing and angle iron and we started cutting/welding/grinding. Here's the frame, it rolls!
139747
Close up of the fishplate and gusset where the trailer tongue meets the frame.
139750
And the top is final welded. Note additional diagonal tying the front frame rail to the side rail. This frame is over built because it may see more than just asphalt or gravel roads.
139748
139749
Flipped over (low rider) to weld the bottom and begin rust/paint removal.
139751
RustyFenderBrewer
Images: 62
Postby RustyFenderBrewer » Mon Feb 29, 2016 11:41 pm
Vedette wrote:Welcome to the Forum
Good Roads
Brian & Sandi
Thanks, Vedette. I read through your build on the web, not sure if it was here. I really like it. Really made me start thinking about other (future) possibilities. Great job - it looks fantastic!
RustyFenderBrewer
Images: 62
Postby RustyFenderBrewer » Tue Mar 01, 2016 7:41 am
Next we added angle iron across the frame width to support two under-trailer storage boxes. The "boxes" are actually cement mixing pans from the home improvement store. They will be stored inside while traveling and provide a great place to keep shoes and other dirty things so the inside will stay clean. I also welded on rear stabilizers and a receiver for a bike rack. (Frame is upside down in the next three pictures.)
139752
139753
139756
139757
RustyFenderBrewer
Images: 62
Postby be_a_jayhawk » Tue Mar 01, 2016 7:11 pm
Very nice start, I'm over in Olathe. Hope to see this one day soon at Hillsdale or Clinton Lake!
be_a_jayhawk
Postby finleycraft » Wed Mar 02, 2016 1:09 am
Gonna be awesome, I am in OP. Are you going to build yourself one when you are done? :thinking:
finleycraft
Images: 87
Postby RustyFenderBrewer » Wed Mar 02, 2016 6:56 am
be_a_jayhawk wrote:Very nice start, I'm over in Olathe. Hope to see this one day soon at Hillsdale or Clinton Lake!
My brother and I are also Jayhawkers. Thanks for reading! Clinton & Hillsdale are likely but we usually go to Pomme de Terre. I know that my brother and his wife are hoping to get much further out with this though.
Last edited by RustyFenderBrewer on Wed Mar 02, 2016 7:05 am, edited 1 time in total.
RustyFenderBrewer
Images: 62
Postby RustyFenderBrewer » Wed Mar 02, 2016 7:03 am
finleycraft wrote:Gonna be awesome, I am in OP. Are you going to build yourself one when you are done? :thinking:
I'm in Prairie Village. My brother is next door in Fairway. Thanks for the response. I think I saw the trailer in your avatar on Craigslist?? If so, very nice!
Yes, I've actually wanted to build one for years. When I mention the interest, my sister in law got really excited about the idea. They were just back from camping trip in the Pacific NW and had seen several teardrops. Looked like an opportunity to get on the learning curve.
RustyFenderBrewer
Images: 62
Postby RustyFenderBrewer » Wed Mar 02, 2016 7:27 am
Okay, I'm realizing I don't have a good picture of the auxiliary table supports we'll be adding. Best pic is one I already posted with the grumpy looking supervisor (our 85 year old father). If you zoom in on the rear corners you can see I installed receivers at a 30 angle to accept a metal leg table which will attach to the trailer side. If you use both, you'll have a U-shaped kitchen to work in. Note: both my brother and his wife are "lefties" so they do everything backwards :D ! Here's that pic again so you don't have to go look for it.
139757
I left off before with the frame finished so it's on to the trailer floor. The plan is to make this at least a three-season camper. With the mild winters we've had the last several years you could use this year round as we've got it planned. The trailer floor is sandwich construction using OSB for the upper and lower skins and 1x lumber for the frame. It is insulated with 3/4" foam sheeting.
139758
139759
139760
After completing the floor we needed to waterproof it. My brother only lets me use the best tools for a job and provided a stick and a tin can to get the job done. And it got done. :)
139761
RustyFenderBrewer
Images: 62
Postby RustyFenderBrewer » Wed Mar 02, 2016 7:41 am
Getting that heavy, sticky mess on to the trailer and flipping it from jelly-side up to jelly-side down was a challenge. Next time I plan to use the stick-on asphalt sealer. I used a full gallon of Black Jack fiberglass reinforced roofing cement so it would seem to be only slightly more expensive to avoid the mess. Oh, well. Here's the floor in place. Note the hurricane ties sticking out which will allow us to tie the walls across the floor to the trailer frame.
139762139763
And it's time to build the walls! They also will be frame and panel construction with 3/4" foam between using birch plywood for the skins. Current plan is to wrap the top in aluminum but leave the birch visible on the sides. Since it's almost 9 1/2 feet from front bulge to rear bulge that means we'll have to deal with a visible seam on the exterior. The interior seam will come at the rear bulkhead. We started with the interior plywood (best side down) and began laying out the wood frame.
139764
Before we attached any thing to the plywood we copied all the perimeter pieces then we got serious.
139765
139766
RustyFenderBrewer
Images: 62
Postby RustyFenderBrewer » Wed Mar 02, 2016 7:47 am
The tail section of both walls is solid plywood. We did this since it didn't require insulation and we haven't finalized attachment points for the auxiliary tables and anything else we may come up with.
139789
Time to make the other side.
139767
139788
And this catches us up with last night. We're just over 4 weeks in and having a blast building this. The rest of this thread will be updated in semi-real-time. You can also follow on Instagram by searching #engelkenteardroptrailer.
RustyFenderBrewer
Images: 62
Postby be_a_jayhawk » Wed Mar 02, 2016 8:58 am
Be sure to check out my build thread so if you see me around you can say hi. If mine is around it's hard to miss!
be_a_jayhawk
Users browsing this forum: jdeleon and 1 guest
