Overland Trailer build Jkidd6339
Re: Overland Trailer build Jkidd6339
Postby jkidd6339 » Wed Mar 02, 2016 8:11 pm
My plans are to sheet with aluminum. I could see using the glue and paint method as a good way to save some money. My 2009 teardrop has held up very well.
My CPES came today the body will get 2 coats with more time spent on the edges.
jkidd6339
Postby dales133 » Wed Mar 02, 2016 10:49 pm
Looking great[THUMBS UP SIGN]
dales133
Postby tawright915 » Thu Mar 03, 2016 3:23 pm
jkidd6339 wrote:Yes Baltic Birch
Curious, what was the thickness and how did you attach it?
tawright915
Postby jkidd6339 » Thu Mar 03, 2016 11:00 pm
6mm about 1/4" on the ceiling glue and just enough staples till the glue sets. The walls will be glued and pin nails to hold it in place while it sets.
jkidd6339
Postby swoody126 » Thu Mar 03, 2016 11:52 pm
are you familiar with the fiber/polymer nails & staples?
got mine from Duckworks along with the pneumatic gun to shoot them
don't rust and can be sanded & painted/varnished over w/o damaging sand paper
supposedly stronger than metal nails & staples
justa thought
sw
swoody126
Postby jkidd6339 » Fri Mar 04, 2016 9:24 am
swoody126 wrote:are you familiar with the fiber/polymer nails & staples?
justa thought
sw
First time I've ever heard of them. Haven't seen any rust on the 2009 teardrop. Not concerned about water getting to any nail, pins, staples or screws. I am terrified about water getting to any of the wood. If you look at my 2009 build you can see what I did to stop the water. It has no water damage. It has worked so good I'm following the same process I used then. Don't get me wrong though I'm up for new ideas just way to late on this one.
jkidd6339
Postby jkidd6339 » Mon Mar 07, 2016 8:59 am
The insulation is in and the inside walls are up. I will do the trim a little later.
jkidd6339
Postby StPatron » Mon Mar 07, 2016 10:13 am
Lot of progress. Congratulations! This is a faaaaast build.
StPatron
Images: 297
Postby lfhoward » Mon Mar 07, 2016 10:42 am
The interior is looking fantastic. Nice work! 8)
lfhoward
Postby jkidd6339 » Wed Mar 09, 2016 9:10 am
Thanks guys hoping to have it usable by May. I doesn't need to be finished until October.
jkidd6339
Postby jkidd6339 » Sat Mar 12, 2016 11:37 pm
Three coats penetrating epoxy.
jkidd6339
Postby KCStudly » Sun Mar 13, 2016 1:01 pm
Very nice. :thumbsup:
Postby jkidd6339 » Sat Mar 19, 2016 11:33 pm
Got a little more work done today.
jkidd6339
Postby Vedette » Sat Mar 19, 2016 11:44 pm
Looking Great! :thumbsup: :thumbsup: :thumbsup:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby lfhoward » Sun Mar 20, 2016 7:56 am
The aluminum looks great! What sheet thickness did you use? I have 0.04 aluminum on my build and it is too thick to bend in a roofing brake. How did you go about bending the roof over the front and rear walls?
lfhoward
