Kind of like a Grumman
Re: Kind of like a Grumman
Postby ELM » Sat Mar 05, 2016 10:04 pm
Today I put the floor back in and drilled and tapped for holes for 1/4-20 brass flat head screws to hold the floor to the steel tubing.I also used Loctite glue. Image total weight here is 467.1 lbs
Also today I added Alder wood where I need it for attaching the 1/4" Baltic beach plywood walls and I refitted the inside walls before removing them again to give them there final coat of poly.
My Build journal. viewtopic.php?f=50&t=65395
ELM
Images: 176
Postby JmsCaverly » Sat Mar 05, 2016 11:01 pm
Well look at that you got some walls up! Looks nice. I like how you did a metal frame. Do you think it will raise the weight at all compared to wood builds. I.e. Like mine. I plan to get mine weight this week so I can file for my Vin number.
Come visit my build journal
139728 139588
viewtopic.php?f=50&t=63870
JmsCaverly
Images: 175
Postby ELM » Sun Mar 06, 2016 1:21 am
I'm weighing everything as I build. Our teardrops will be a good comparison because there about the same size and shape. It will be very interesting to here what your weighs. Why do you need to weigh it ? From what I've read on the DMV web site if it's under 16' long and you call it a camp trailer not a RV you can get the PTI plates. But thing do change once your at DMV :frightened: :?
ELM
Images: 176
Postby jmascioni » Sun Mar 06, 2016 1:30 am
You have an awesome beginning.
I think that your craftsmanship in steel is amazing. Fantastic job so far. :thumbsup:
jmascioni
Postby ELM » Sun Mar 06, 2016 11:19 am
jmascioni wrote:You have an awesome beginning.
ELM
Images: 176
Postby Vedette » Sun Mar 06, 2016 1:58 pm
Great looking trailer! :thumbsup: :thumbsup:
Always nice to someone else "Welding" :thinking:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby ELM » Sun Mar 06, 2016 9:46 pm
Made a little more progress today. I glued the interior wall to the metal framing with Loctite adhesive. Image
I almost used all off my clamps Image
I also started on one of the bulkhead walls :) Also I've decided to do a running weight on it while building. So I will go back and add the weights to my previous posts.
Total weight here with walls and one tube of Locktite. Grand total so far is 500.2 lbs
Forgot to add rims and tires 82.4 lbs
Grand total is 582.6 lbs
ELM
Images: 176
Postby KCStudly » Mon Mar 07, 2016 9:38 am
Cool. :thumbsup:
I'll be very interested to see how closely you running total compares to the actual final scaled weight. :thinking: It will be kind of a subjective comparison given the different glues, paints, etc. that are hard to predict cured weight of, and the possibility of forgetting weigh something prior to installation, but still should be interesting to compare.
Postby ELM » Tue Mar 08, 2016 10:15 pm
I've been working on the lower bulkhead wall the past few days. I used 1 1/4 PVC for my water tank and the 1/2" CPVC you see in there is for the hotrod heater. I'm going to use thishttp://www.jegs.com/i/JEGS-Performance-Products/555/70603/10002/-1?parentProductId=
With one can of foam
With foam finished and I cut the excess off with a hand saw.
And all closed up but still needs one more coat of poly.
ELM
Images: 176
Postby jmascioni » Wed Mar 09, 2016 1:13 am
2 questions...1. how many gallons of water does your cool looking water tank hold? and 2. The link you provided isn't for a water heater, its a heat system that extracts heat from the anti-freeze in your car. Taking heat out of the water that circulates in the motor. It doesn't have a pump or any way to make heat. What is your plans for that?
jmascioni
Postby ELM » Wed Mar 09, 2016 1:28 am
I haven't filled it yet to check the capacity. I'll do that tomorrow. The link is for the heater that I will be running off of my hot water heater. I hope that answered your questions. Thanks
ELM
Images: 176
Postby ELM » Wed Mar 09, 2016 3:20 pm
jmascioni wrote:2 questions...1. how many gallons of water does your cool looking water tank hold? and 2. The link you provided isn't for a water heater, its a heat system that extracts heat from the anti-freeze in your car. Taking heat out of the water that circulates in the motor. It doesn't have a pump or any way to make heat. What is your plans for that?
I filled it with water and it holds 3.25 gallons. I'm happy with that amount of water. :)
ELM
Images: 176
Postby ELM » Sun Mar 13, 2016 12:00 am
I've been working on it so here's an update. I installed the lower bulkhead wall / water tank and started on the ice chest tray. Total weight 614
Also worked on the dividing / support wall. Total weight 629
This is the frame work for the counter top framing.635
upper bulk head wall.
ELM
Images: 176
Postby ELM » Sun Mar 13, 2016 12:16 am
Picture of galley
Started on the inside cabinets and A/C
Back side of A/C. Next I need to figure out the ducting for back side of the A/C. :thinking:
I will be working on figuring out the wiring :thinking: :? :thinking: :?
ELM
Images: 176
Postby Vedette » Sun Mar 13, 2016 12:38 am
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
