daddytall wrote:Party poopersI'm going to do it! Looks like the material can be had for a couple hundred. http://carwrapsupplier.com/services/pro ... ing-films/
If I can figure out how to post pics here I'll post up.
daddytall wrote:I'm a GC so I *think* I can pull off the install. My 16 yo boy and I are building this together, so taking on the wrap job will be a lesson, hopefully a lesson in success.It's luan skinned and will get epoxy coated, body work, prime, paint and finally a wrap. I've painted cars before, so we are "going for it". Did I mention diamond plate flames and 48x48" skylight?
Now where is that damn pic button?
starleen2 wrote:daddytall wrote:I'm a GC so I *think* I can pull off the install. My 16 yo boy and I are building this together, so taking on the wrap job will be a lesson, hopefully a lesson in success.It's luan skinned and will get epoxy coated, body work, prime, paint and finally a wrap. I've painted cars before, so we are "going for it". Did I mention diamond plate flames and 48x48" skylight?
Lesson learned: If you are really going for it - the epoxy coating is enough, the paint really isn't necessary if you are going to wrap the entire camper (or just paint what is not being covered)
One thing most videos do not mention is to spray the adhesive side as well as the surface with a light mist of soapy water solution (usually about three drops of soap per quart will do) this will prevent the vinyl from sticking to itself.
