On his sidewalls, he has a notch cut out for the hatch. On other plans I have viewed, there is no notch cut out for the hatch. I’m trying to understand the difference in the builds and pros/cons of each design. It seems the notch allows the hatch to “overlap” the wall in the rear via use of some aluminum trim. If no notch is used, the hatch closes within the two walls. Am I right?
On that same note, there are two hurricane hinges on the market – one has offset, one without offset. This is related to the notch above (I believe).
Can someone guide me through understanding these issues before I cut walls and order hinges. Thanks very much.
