gudmund wrote:One question I do not see here has to do with a Honda Fit towing a 5x8 sized trailer. A Fit is smaller than a Civic but bigger than say my Geo Metro/Suzuki Swift, but not by much. After towing my 4x8 well over 15000++ miles with my mid-sized PU and no trailer brakes, would I ever try to tow it with my Geo/Suzuki Swift?? NO !! and it has great brakes!! (couldn't care less what others thing of them, am on #7 after 300thou miles of use out most of the others!!) First off it is not even rated to be able to tow anything along I don't even think a hitch is even made for one. My point here is, if I was to even think about towing with a car this small, the first thing I would be concerned with was finding a trailer with trailer brakes (electric brakes). The trailer will weight what is empty but than weighted down with A/C etc. along with whatever you are planning on carrying when traveling, how much weight are we talking about?? Mine starts at about 900 lbs. and ends up at about 1250 to 1400 lbs. loaded along with whatever other weight is added to the car/truck itself when traveling. The trailer-world along with a lot of states say that trailers over 1500 lbs. need trailer brakes (my owners manual for my last 3 PU's states that any trailer over 1000 lbs. should have trailer brakes which is probably written in there to protect the vehicle manufacturer probably just to say - we told you so!). Mine does fine without them but I can tell you, there are times when I could have used them when going some down hills I've been on being I do feel the weight back there!!!! And now to finish, if I can remember these words that someone has written on this website that I have read here before goes something like ....You can go down a hill over a thousand times slow, but the first time fast - could be your last!!... take care and stay safe
So, I don't know what the little guy is rated for weight, but my 5x8 benroy that I built to be light weighs in at 860lbs loaded for war. (quick google check says 1060lbs for the 5x10 ss)
I tow just fine on a 1.8l Scion XD (rated for 2000lbs in the UK, not rated in the US) as long as I am reasonable with it. You don't need a gigantic rig to pull a teardrop. Now I know people go back and forth on this, but the Honda Jazz (same car as the fit overseas) is rated to over 2000lbs as well.
Drive slow, be careful and know you're making your own choices and taking your own chances, and you will probably be just fine.
