by Artificer » Sat Jun 17, 2006 9:26 am
You could also do a splined joint. Use your edge guide to position the blade in the middle of the plywood. You can clamp a 2x4 (or two) to the edge to give you a stable surface to run the circular saw on. Do both pieces of plywood, guiding from the same side. If you need a wider slot, move the guide, and recut.
I like to use 1/4" plywood as a spline. (1/4" plywood underlayment... no voids) The outside ply grain of the spline goes perpendicular to the main plywood edge.
If you're carefull, you can get as good of results as the biscuit, and have a stronger joint, since the spline goes the entire length of the joint.
If you don't have the circular saws edge guide, you can glue/screw one up from plywood and a 2x4. Make a Tee, and clamp or screw the plywood to the saws foot. If you go this route, you don't have to clamp a 2x4 to the plywood, since its on the guide. Attach the guide to the saw with the blade fully raised. Once its secure CAREFULLY!!!! turn the saw on, and plung cut through the plywood of the guide. You can also pre-cut the blades slot, which is safer, and makes it easier to adjust the position of the guide.
