#1
Re: #1
Postby TheOtherSean » Thu Mar 24, 2016 11:01 pm
Looking good! :thumbsup:
TheOtherSean
Images: 111
Re: #1
Postby ghcoe » Fri Mar 25, 2016 9:05 am
TheOtherSean wrote:Looking good! :thumbsup:
Thanks....
One project yesterday was installing the door latching system. I am using storm door handles for this build. I am using my foam reinforcement technique for this process. First I cut out a reinforcement plate, in this case a piece of 1"x2" flashing. Then I take the soldering iron and make a slot using the flashing edge as a guide. Now I am able to glue and install the reinforcing plate. This makes for a good hard point for installing the interior latch. Before I glued the plate in I did predrill the holes for the latch.
Grooving for reinforcement plate
Reinforcement plate interior
Drilling holes for latch
George.
ghcoe
Re: #1
Postby ghcoe » Fri Mar 25, 2016 9:15 am
Some shots of the gluing process.
Gluing with cualking
Glued
George.
ghcoe
Re: #1
Postby ghcoe » Fri Mar 25, 2016 9:23 am
Same procedure for the outside.
Outside reinforcement plate
Also, got the foam grooving for all the wiring done. Now I just need to install boxes, run wire and recover and fair in wire grooves and that will be done. The hatch is nearly faired out and should be ready for canvas and then installed soon. Week is nearly over though so things will slow down again. :thumbdown: I am beginning to see the end now though and that is good.
George.
ghcoe
Re: #1
Postby GPW » Fri Mar 25, 2016 10:06 am
:thumbsup: Just the flashing and the foam eh ?? Cool !!!
Re: #1
Postby ghcoe » Fri Mar 25, 2016 11:01 am
GPW wrote::thumbsup: Just the flashing and the foam eh ?? Cool !!!
Yup. I purchased longer bolts for the handle so they can reach through the extra door thickness on the foamie. With the handles on both sides of the door it will create a clamping action on the foam. The flashing is so it will spread the pressure across the foam surface and keep the handles from compressing the foam. Also keep the foam from breaking or bolt holes from enlarging with use. The only wood in this build so far is in the floor. All hard edges and hardware attachment points are flashing and or drywall beading.
George.
ghcoe
Re: #1
Postby GPW » Fri Mar 25, 2016 4:14 pm
That’s very Cool ... No wood , no worries ... :thumbsup: 8)
Re: #1
Postby ghcoe » Sun Mar 27, 2016 5:33 pm
GPW wrote:That’s very Cool ... No wood , no worries ... :thumbsup: 8)
Well one would hope. Still in the test mode only time will tell.
George.
ghcoe
Re: #1
Postby ghcoe » Sun Mar 27, 2016 5:39 pm
Last day of break. Manage a few things. The door handle is now mocked up, just need to make the striker plate to take up the slack in latch to threshold.
Door handle
Inside and outside handle
Inside handle
George.
ghcoe
Re: #1
Postby GPW » Sun Mar 27, 2016 5:45 pm
Nice job !!! :thumbsup:
Re: #1
Postby ghcoe » Sun Mar 27, 2016 5:46 pm
Installed flashing to the shelving to give shelves a bit more support than just one piece of flashing. Installed electrical boxes where needed. Getting closer.....
Galley electrical
George.
ghcoe
Re: #1
Postby ghcoe » Sun Mar 27, 2016 5:48 pm
GPW wrote:Nice job !!! :thumbsup:
Thanks. :thumbsup:
George.
ghcoe
Re: #1
Postby roamer » Mon Mar 28, 2016 8:37 am
You could also cut tubing(sleeves) to the thickness of the foam and insert in wall where the bolts will be.
They would stop any compression, but would allow the bolts to be torqued down. The flashing would distribute any other stresses on the foam.
Dave
If you think you can't, you won't
138765
roamer
Images: 25
Re: #1
Postby GPW » Mon Mar 28, 2016 10:55 am
Any thoughts on bending/folding that flashing and using Pop rivets to make rudimentary FRAMES for the foam pieces ( or entire cabins ) ... throw in a couple anti compression PVC tubes like Roamer said ... and Bob’s your ... :thinking: No wood , no worries , and you could cover over all that with an outer skin , perhaps that FRP product like Ken W used, or even canvas , or chipboard ... :o ... Interesting !!!
Re: #1
Postby ghcoe » Mon Mar 28, 2016 8:27 pm
GPW wrote:Any thoughts on bending/folding that flashing and using Pop rivets to make rudimentary FRAMES for the foam pieces.
Not sure if I understand what you are getting at. I did make frames to fit around the doors on my first attempt and installing hard edges. It actually worked real good and looked good too.
Door framed
I found that you would have to have your measurements and bends perfect for a good fit. I worked with it a bit, but went with this new way to make assembly a bit easier.
George.
ghcoe
