plunging on another build
Re: plunging on another build
Postby Wolfscout » Tue Mar 29, 2016 3:45 am
It's not that the boat is big but I don't want to put it inside. Already have a golf cart going inside. The winch is to make it easier to load it up there. Sometimes we take a boat and don't get a chance to use it. This way (plan is) if we don't use it, it's not going to be in the way or have to be carried in and out of the camper during our stay. We just have to move it forward to free up our "sitting area". lol
Sure, I'll have a GFI receptacle. I have already put one on the side.
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby flboy » Tue Mar 29, 2016 7:18 am
I see. That makes sense on the boat.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby flboy » Tue Mar 29, 2016 7:34 am
You are making great progress. Sounds like you will be ready for a maiden voyage soon. Way ahead of me. It is hard to find time to focus on the build ... but I am trying. My goal is to finish by July.
Don (Flboy)
flboy
Images: 378
Postby flboy » Tue Mar 29, 2016 9:26 am
Larry, when you cut the holes for your windows, what did you use to cut and did you leave up the interior siding to cut through both at the same time. I am planning on using a jigsaw with a blade for metal/wood and cutting both at the same time, then taking off the interior siding after so I can weld the window frame supports and then insulate and caulk. Thoughts?
Don (Flboy)
flboy
Images: 378
Postby Wolfscout » Tue Mar 29, 2016 10:20 am
What I do is Mark where I want the window from the inside and draw it out with a square measuring from the ceiling line if I can.
Then I drill a half in hole and cut it out with short metal or wood bit. ( I like metal as it leaves a better cut) Using a jigsaw. Then I use a ice pick (LMAO) and punch my four corners. The reason I use a Ice pick is I can set a string level on it and get a good tight fit on where it will be on the outside. Then When I go outside I can see the 4 corner marks and just need to take a large square and draw it out again. Putting Blue painter's tape on the outside and inside of the cut for the jigsaw to slide over seems to work best for me. I've put 10 windows total (8 on my two campers and two for a friend) and haven't had a problem yet.
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby Wolfscout » Tue Apr 05, 2016 7:30 am
couple images from the weekend working on the upper deck.
rear view (not shown a roller for the cable I added.)
side view
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby Wolfscout » Tue Apr 05, 2016 7:33 am
two more images of the winch set up for my boat loader.
closer shot.
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby Wolfscout » Tue Apr 05, 2016 7:34 am
Yep that upper deck is extra stable. I think it'll work for holding out small boat and some gear.
Occassionally, we may want to take a stool or two up and sit and enjoy the sites. especially at the beach without ever getting in the sand. :lol:
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby flboy » Tue Apr 05, 2016 7:36 am
Looking good Larry!
Don (Flboy)
flboy
Images: 378
Postby Rainier70 » Tue Apr 05, 2016 10:16 pm
Rainier70
Images: 244
Postby Wolfscout » Wed Apr 06, 2016 7:46 am
It appears that my current plan on the RV tub is going to have to be nixxed for now. There's a metal frame tube 2" wide that runs about 1/4 inch off beneath where the tub drain has to go. If I move it inwards I won't have width room for the Golf cart or boat inside. First trip is now 17 days and counting down. ARGH!!
Have I said yet that I hate doing plumbing?? :?
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby flboy » Wed Apr 06, 2016 9:13 am
Build a subfloor 6 inches up and plumbing goes under there. I have to do this in my CTC to get a p trap in prior to dropping on the gray water tank.
Don (Flboy)
flboy
Images: 378
Postby hankaye » Wed Apr 06, 2016 9:29 am
Wolfscout & flboy Howdy;
Have only seen these http://www.hepvo.com/ in 1.5" size.
so won't do for Black tank applications.
Just an idea to kick around ...
hank
hankaye
Postby flboy » Wed Apr 06, 2016 3:33 pm
hankaye wrote:Wolfscout & flboy Howdy;
hank
That looks interesting. My issue is that my shower pan is not over the gray water tank and I need a little elevation change to let gravity work. That being the case, I need to build the shower pan up higher then the rest of the flooring. Since I have to do that, the P trap is no problem.
flboy wrote:Build a subfloor 6 inches up and plumbing goes under there. I have to do this in my CTC to get a p trap in prior to dropping on the gray water tank.
Don (Flboy)
flboy
Images: 378
Postby Rainier70 » Wed Apr 06, 2016 7:27 pm
I agree with flboy. Probably your easiest solution is to raise you shower pan up with a false floor. I have used a shower with a slight step up, and it worked fine. Kind of depends on your ceiling height too though. I would fill much of the false floor space with foam to support the pan.
Rainier70
Images: 244
Users browsing this forum: Bing [Bot] and 8 guests
