My Off Road Build Journal
Re: My Off Road Build Journal
Postby KCStudly » Mon Apr 11, 2016 7:20 am
I pressed a PVC union half into a just rightsized hole sealed with calk, then screwed a Sealtite style electrical flex conduit fitting into that.
Check out these posts in my build thread:
http://www.tnttt.com/viewtopic.php?p=1081749#p1081749
http://www.tnttt.com/viewtopic.php?p=1081874#p1081874
Postby dales133 » Mon Apr 11, 2016 12:34 pm
Google cable gland... its another good option
Sent from my SM-N910G using Tapatalk
dales133
Postby big44g » Sat Apr 16, 2016 9:52 pm
Thanks everyone for the great ideas on the electrical, Now i feel better about finding a good solution
Gary Fulton
Baton Rouge, LA
My Build Pictures: https://bigg.smugmug.com/Teardrop/
My Build Journal: viewtopic.php?f=50&t=64524&p=1147662#p1147662
big44g
Postby big44g » Sat Apr 16, 2016 9:54 pm
Thanks, and I like that cable clam. And I thought I looked everywhere on the blue seas web site
Wobbly Wheels wrote:Just found your build thread - you've got some skills ! :thumbsup:
big44g wrote:What do you use to seal the electrical that exits the camper to the battery box?
Looking at your pics, I see a Blue Sea fuse panel. They also make a product called a Cable Clam. They are the only way I've found to make a reliably weather tight deck penetration on a boat.
Gary Fulton
Baton Rouge, LA
big44g
Postby big44g » Tue May 24, 2016 9:10 pm
I think I am ready to skin it. Here she is;
My plan is to add a 60 inch truck box on the front for Batts etc. With 12 years in the scouts and as a troop Scoutmaster I like the scout patrol box for cooking gear. So I will add an aluminum "Scout Patrol" style cook gear box on the back. I have gone back and forth on filon or aluminum. I just like that airstream look so I have decided on aluminum. I have found some 0.063 5x10 aluminum sheet. So finally my question; will the .063 aluminum wrap around the 18 radius I have on the front and back?
As always thanks for the help
Gary
Gary Fulton
Baton Rouge, LA
big44g
Postby big44g » Fri Nov 18, 2016 7:04 pm
I know I have not been posting much (or at all). But I thought I would give an updated picture. I know I like looking at pictures to get ideas. It's not done, but a few weekends ago we decided to take her out for a weekend. Had a great time. I have to finish out the box galley, water tank, tankless heater and pump. I am adding a spare tire holder on the front and I need to add/finish outside lighting.
You can see all my pictures at https://bigg.smugmug.com/Teardrop/
Gary Fulton
Baton Rouge, LA
big44g
