Floor question
Floor question
Postby Bil D » Tue Apr 19, 2016 8:05 am
Thanks everyone for your tips and ideas.Great forum
This my first build
Question.
Do you see any problem with attaching floor and cleat as per pic?
My reasoning is, I can check bolts from time to time and tighten ,also can remove from trailer as the need arises
cheers for now
Bill
Floor to Frame.jpg (91.75 KiB) Viewed 1240 times
Bil D
Re: Floor question
Postby KCStudly » Tue Apr 19, 2016 7:50 pm
Looks okay to me. :thumbsup:
Re: Floor question
Postby Bil D » Wed Apr 20, 2016 12:19 pm
Thanks KC
I havn't seen another method like this on the forum (exposed bolts )
So thought I'd ask the forum
Better get on with it now.
Cheers Bill
Trailer is an Easy Trailer (Aus ) )similar to your HF
TEARDROP 2 floor.jpg (89.31 KiB) Viewed 1191 times
Bil D
Re: Floor question
Postby dales133 » Wed Apr 20, 2016 2:43 pm
Looks good to me to.
The other way you could do it though is fit T nuts in the floor and bolt into them from underneath then you can put a perminant floor covering over them,both methods will work just dandy though
dales133
Re: Floor question
Postby KennethW » Wed Apr 20, 2016 2:53 pm
dales133 wrote:Looks good to me to.
I did the t nuts with a sheet of insulation under the floor. and a 1x4 cleat glued and screwed from the bottom up to mount the wall on.
KennethW
Images: 82
Re: Floor question
Postby dales133 » Wed Apr 20, 2016 2:59 pm
Ive used T nuts on mine to.
Recessed into the frame and the plywood internal flooring and comercial grade linoleum over that.
I dont intend to take mine off the frame at any point but it makes assembly a one man job
Where abouts in Aus are you Bill
dales133
Re: Floor question
Postby lfhoward » Wed Apr 20, 2016 4:51 pm
Bolting it to the frame has worked well for me. I used washers on both the top and bottom, as well as nylon lock nuts underneath so they don't rattle loose.
lfhoward
Re: Floor question
Postby Bil D » Thu Apr 21, 2016 9:24 am
Thanks again folks for your help ,very appreciated.
Things can change I know... but the plan now is ,,,,,,
Walls sit on trailer frame ,overhang 1/4 " (room for bolts)
Cleats above floor bolted as per suggestions
No formal Galley at this stage just a benchtop.
No power ,(Shore or 12V ) will use portable lighting and cook outside
No roof hatch but will reinforce spars for future installation
Wiley Windows
S/S piano hinges for Galley hatch and doors
Insulation --roof and bulkhead only
Varnish inside ....Paint outside
Bet i've missed somthing
Pretty basic I know ,a "Bed in a Box" really but can modify it as needed
Hope to post a build journal
Cheers and thanks
BIll from Victoria Aust
Bil D
Re: Floor question
Postby lfhoward » Thu Apr 21, 2016 12:20 pm
Sounds good to me! It sounds like you'll have everything you need, and other options can be added later. The KISS (keep it simple) principle will make it more affordable too. You'll be out enjoying your camper sooner.
lfhoward
Re: Floor question
Postby dales133 » Sat Apr 23, 2016 12:27 am
Sounds like a sound plan bill.
Im in Vic too, Geelong to be exact
dales133
Re: Floor question
Postby GuitarPhotog » Sat Apr 23, 2016 10:47 am
Since piano hinges are not intrinsically weatherproof, you might consider using a 2-piece hurricane hinge for your door and hatch. Much less trouble than trying to weatherproof a piano hinge.
<Chas>
:beer:
GuitarPhotog
Images: 55
Re: Floor question
Postby dales133 » Sat Apr 23, 2016 1:13 pm
Huricane hinges are avaliable here in australia from aussie teardrops in queensland by the way
dales133
Re: Floor question
Postby Bil D » Sun Apr 24, 2016 7:53 am
Thanks again for your help.
Hurricane hinge was first choice but hard to find
The ones from Qld are 1.52m w my TD will be about 1.52m with the overhang
Has been suggested hinge needs to overhang the sides.
for now Bill
Bil D
Re: Floor question
Postby Bil D » Thu Apr 28, 2016 7:23 pm
Back again ,thought I had it worked out .
Hi
Has anyone had succcess bending 6 mm / 1/4 inch marine ply sideways over 20 inch (front) and 48 inch radius? ( hatch)
Or is one layer of 4 mm enough???
thanks, Bill....
Bil D
Re: Floor question
Postby dales133 » Thu Apr 28, 2016 11:18 pm
Bill rainer at aussie teardrops can supply any le th you want.
Mines 1680
dales133
