TheOtherSean wrote:Just remember to remove the kiddies from the trailer before towing.
ELM wrote:Looking awesome. I like the angled side table I might steal your wife's idea.
KennethW wrote:It looks like you had the nut to tight and or not packer right(you have to get the grease in the bearing between the rollers Not just in the outside). As the bearings heated up it got even tighter. The way a do it is spin the hub when tighten when you fill a little resistant loosen a 1/4 turn. Better to be loose then too tight. I have not heard of a bearing failing from being a little loose. A teardrop is a very light load so I don't see a problem with the axle. I would run it as long as the out side bearing still fits right and is not loose on the axle . Most axle low carbon steel that will not get hard and break. But this is just my thoughts.
JmsCaverly wrote:I can tell you it was really easy. You need to fill out two forms one for the trailer build and one for registration. Make sure you have the receipt for your steel, axle and wheel/tires that's what they need for proof you built the trailer and didn't steal it. They want to know the estimated cost of the build I told them mine was round $8500 which I'm getting pretty close to, then she wanted to know what I thought what the weight was I told her about 1300 or 1400 Next she asked me if I had my trailer with me and I did, she asked me to pull up to an inspection area where she came out and asked me to do a light check. I signed the registration papers she handed me the VIN number sticker and told me she had to watch me stick it on ( my guess if for fraud check) then we went inside, she didn't some more work on the computer handed me a lisence plate, gave me my registration paper and off we went pretty simple process.
JmsCaverly wrote:Well I definitely didn't know that the axle nut needed to be backed off a bit, I know for sure its not from the lack of axle grease considering the amount of bearing grease I had to clean off the wheels. And there is still a lot of grease still inside the hub and on the bearings themselves.
It's good to know that the axle isn't bad, I was kinda sure it wasn't but I haven't done anything with trailers before so this helped.
Thanks for the info.
