jstrubberg wrote:Socal;
What type of plug do you have on the unit? Is it a standard AC adapter or something along the lines of a micro-usb style?
jstrubberg wrote:Looks like the pogo only needs 5v, so something like this should do the trick
http://www.amazon.com/SMAKN-Converter-P ... 5v+adapter
Socal Tom wrote:I'm creating a small portable media server for traveling. Its a pogoplug v3. I've got it setup to provide a wireless access point, and serve video through a dlna server.
bdosborn wrote:I use a carnetix cnx-p1290 voltage regulator to run my PC in the camper at 12V. I use it to run my LCD TV as well:
jstrubberg wrote:I'm using a raspberry pi running Kodi for my media needs. I've never streamed FROM it though, always to it. Looks like it can be done using VLS, but I haven't tried it.
Very solid device, and I've run it for several hours off of a 18,000 milliamp cell phone battery. 5V, too.
Shadow Catcher wrote:I am using a couple of pulse width modulation DC DC for a number of functions including regulating fan speed on the bilge blower and dropping voltage so that I can run our 6V weather radio off of 12V. Checking with a VOM the digital read out and stability seem to be good. I have used two of these http://www.amazon.com/DROK-Numerical-Switching-Adjustable-Stabilizers/dp/B00BYTEHQO/ref=pd_sim_23_4?ie=UTF8&dpID=51qwzjy58HL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=101KT9X9SEEQCXB6R1Q6
Here you can see I am using two 12 batteries in series through the PMW while testing an LED array to destruction (two of the SMD's unsoldered them selves an fell off).
